Auto Provisioning Help
Chazoo15
16
Hey guys, I'm struggling. I've got a new system up and running. When I manually provision the Yealink, it comes right up. As soon as I try to auto provision, no bueno.... I did a stare and compare with my other systems and all look identical. Read all of the docs and still nothing. The only difference is this one is hosted at Vultr the others are in my own colo space. Any help or insight would be greatly appreciated!
bcmike
326
How do you provision via http or https? Have you set credentials? Try to provision via http and on your fusion machine, via the command line run:
ngrep -d ens15 port 80 -W byline
You will have to replace ens15 to whatever your adapter name is. You should see http messages scroll by with some clues on what might or might not be happening.
You may have to install ngrep..
