SOLVED Auto provisioning
derr12
17
I had found one article on how to get auto device provisioning to work, unfortunately, it doesnt work..
http://inside-out.xyz/technology/auto-provisioning-an-aastra-ip-telephone-with-fusionpbx.html
"First you need to do is go to your web server and add a .htaccess file entry. If you are using my RPM's the correct path for this file is /var/www/html/.htaccess. Edit it and add the following lines:
RewriteEngine On
RewriteRule ^.*/provision/aastra.cfg$ fusionpbx/app/provision/index.php?file=aastra.cfg [QSA]
RewriteRule ^.*/provision/([A-Fa-f0-9]{12})(\.(xml|cfg))?$ fusionpbx/app/provision/index.php?mac=$1[QSA]"
however, the vanilla install does not have an htaccess file in the root web directory. using a grandstream gxp2160
has anyone gotten the device provisioning to work? if so can you point me at some documentation?
moteus
13
Default installation uses nginx which does not use `.htaccess` files.
Instead it use rewrite rules. Not sure exact path where they placed thou.
RewriteEngine On
Have you enabled provisioning in advanced/default settings?
EasyBB
240
33
Australia
I believe people are over-thinking provisioning because there's no proper documentation available.........
TheOperator
Bavaria, Germany
@derr12:
are you using a current default 4.2 / 4.3 installation on Debian 8 ?
I recently set up provisioning for my Yealink phones and didn't have to change any settings for the nginx web server.
These are the steps I did to get things working:
In the 4.2 installation I started with, the "enabled" setting in the provisioning section was missing completely and I had to add it by hand. See the comment made by DigitalDaz.
Once that was done, I was able to download the configuration files the phones would see using the download option on the devices page.
Does that work for you ? If it does, then everything should be fine on the server side.
If so, then make sure your phone is set to the correct URL - I have "https://[server-FQDN]/provision" in my phones. As I am using ssl, I also had to install the CA-Certificate on my phones.
Short note: My Fusion-PBX domain is identical to the server-FQDN
That was all I did to get basic provisioning up and running.
I must admit, that I have spent a few hours customizing the templates used to adapt them to my needs, but that is a different story.
derr12
17
@derr12:
In my test setup my domain is just the public IP address for now. ill double check my url and make sure i can get the files downloaded. Appreciate the help guys, i wouldnt be able to do a proper assessment without your help!
derr12
17
If i go to the path of the xml file in the webserver, it's there. I think i just have to sort out this grandstream phone now.
derr12
17
I think thats got it. something so simple! I was botching the file path in the phone, once i used the correct format i grabbed the xml via http no problem.
Vozzie
Hello Derr12,
What's the url you've used in the Grandstream phone? Can't find the correct url anywhere...
sheraz14
33
I've grandstream phone. what file path do i need to use? and do i need to create any xml file inside the path or will it be available ?
