I added a gateway (via Accounts > Gateway) and named it "xyz". Then I added an outbound route. After that I tried to dial a number with my sip client and the route is used. Works fine.
When I try to use this gateway within a dialplan it works when using "transfer +49123456". But when I try to use the bridge-application with data = sofia/gateway/xyz/+123456 I get the error "INVALID_GATEWAY". So "xyz" is not known at this moment.
I noticed that sofia status reports my gateway with an uuid. So if I use the bridge app with data = sofia/gateway/{this uuid}/+49123456 it works.
Is there a way to use the gateway name "xyz" within the data of bridge app?
Thanks in advance,
Thorsten
Thanks in advance,
Thorsten
