bridge Inbound transport=udp to outbound transport=tls
Jul 14, 2020
32
Singapore
www.zionengage.me
thank you for helping.
I have the following scenario (TLS is enabled in SIP profile both Internal & External):
caller incoming (udp 5080) to Server A (udp 5080). Server A should bridge call to Server B (over tls 5081).
I am just testing out but seem not able because I am getting in the Invite showing is UDP and not TLS.
Please share with me how in Dialplan -> Inbound routes, I should set up to achieve it? Doable?
Thanks.
INVITE sip:68176331@sip.server.b.com:5061 SIP/2.0
Via: SIP/2.0/UDP sip.server.a.sg:5081;rport;branch=z9hG4bKFvSceyc2D84aF
Max-Forwards: 67
From: "69507009" <sip:69507009@sip.server.a.sg>;tag=0K0t3a1gN47Fr
To: <sip:68176331@sip.server.b.com:5061>
Call-ID: 07ec8633-73de-123d-9da1-9aac180d09ce
CSeq: 81933363 INVITE
Contact: <sip:mod_sofia@sip.server.a.sg:5081>
User-Agent: FreeSWITCH
Supported: path, replaces
Privacy: none
Content-Type: application/sdp
Content-Disposition: session
Content-Length: 275
P-Asserted-Identity: "69507009" <sip:69507009@sip.server.a.sg>
If I'm understanding your question correctly, bridging outbound using TLS is fairly straight forward. You can pass all the required parameters in the bridge statement:
<action application="bridge" data="{rtp_secure_media=true}sofia/internal/$1@server.b.com:5061;transport=tls"/>
In the above example, we set a channel variable to enable encrypted RTP, {rtp_secure_media=true}, this is optional depending on your requirements. We are using the internal SIP profile in this example. $1 is holding the number you wish to call. Then we provide the destination server name and port. And finally add the parameter transport=tls
