Busy tone
falk
77
Hi
Having a problem when distension internal or external t is busy
I am getting normal clearing when calling
And call is disconnected at the log is |: 486 busy here
Any suggestion how to fix to receive the busy tone???
In your outbound route change:
continue_on_fail=true
to
continue_on_fail=0,2,3,6,16,18,25,27,29,31,34,38,31,32,34,38,41,42,44,58
thanks
now receiving user busy that’s is great but no busy tone –
and Fast disconnect with outbound is failed
The busy tone is not generated by the PBX, that is your endpoint that does that, if you are getting a 486 to the phone then the phone needs to make a busy signal of that.
" and Fast disconnect with outbound is failed", I do not understand that.
ok i will check the end point : yealnik 46s.
how it pussible to fix it on internal call when call waiting is disable
On my yealink, I had to go to settings/tones and choose my country, the default was custom. Now I have a bust tone. Mine is a T46S
fix it working perfect !!! thanks
it possible to fix it for internal call-
if i disable call waiting + voice mail ?
Yes
For external call it working perfect
But when i try for internal occupied ext
I receive normal clearing on screen
I do not, I receive user busy, are you doing a direct call to the extension or is it going an indirect route?
Then the phone should definitely be delivering you a busy tone, certainly does for my country tones.
Reactions: falk
It was the phone
I change it from custom to the correct country
Working perfect
thanks
