Call recording delete after x amount of days
Something along the lines of this in crontab:
0 2 * * * /usr/bin/find /var/lib/freeswitch/recordings/*/archive -type f -mtime +90 -exec rm -rf {} \;
here is ho I do it
I use maintenance script to delete old faxes / voicemail over 30 days
I call maintenece script in crontab like DigitalDaz
#Run fusionpbx-maintenance.sh
#Delete Faxs older than 30 days & clear database whitespace
#Delete voicemail older than 30 days & clear database whitespace
0 21 * * * bash /etc/cron.daily/fusionpbx-maintenance
here is ho I do it
does that not run daily as its in the cron daily folder ..?
It would appear, in the latest version that it actually DOES run.
I was unaware oif this and certainly do not want a db backup every night on the same box :)
You can test it running by:
run-parts /etc/cron.daily
I think in older version, the file had a suffix, like .conf or something and that prevented it running until renamed.
There are a bunch of config variables that it looks like you can enable/disable and tweak the features.
I'm gonna start using this I think, its much sleeker than what it was. :)
Yes, I just did:
mv /etc/cron.daily/fusionpbx-backup /etc/cron.daily/fusionpbx-backup.conf
Now when I do the run parts, the backup of the db does not happen
