Call Transfer
mak_make
50
I am using FusionPBX version 4.5.28 and I had a issue with call transfer.
When the external call comes in Ext#A answered the calls and did blind transfer to Ext#B. when Ext#B answers the call he hear prompt to accept press 1, reject press 2, send to voicemail press 3. If the Ext# B presses 1 then the is connecting.
I don't want to hear the prompts, How I can remove the prompt from the transfer feature.
I have conducted a test on internal calls I don't hear the prompts.
Any Ideas on how to remove the prompts. in Previous versions there are no prompts!!!!
NVGcom
25
Does the Ext#B have Follow-Me enabled with Prompt set to Confirm?
NVGcom
25
Is Call Screen enabled within the Ext#B or on the actual Phone?
The Follow-Me and Call Screen would prompt something like that.
