Hi @ all,
i need your help...
At the first, a short description.
FusionPBX with public ip behind the gateway 92.1.2.3
Country Code +49
Area Code 1234
Base Number 765
Numbers from 7651 to 765999
I have a zyxel gateway 400 (ip 192.168.115.81) for an old isdn pbx
at extension 10000 (on FusionPBX 10.10.10.1/192.168.115.85).
My problem is, that i can not hear sound, after a internal call.
In this example, i call the internal numer 210 from internal extension 6.
The 210 is not local on the fusionpbx, it is behind the zyxel.
I call from the 6 the 210... (so ${destination_number} = 210) with my route fusion does bridge:
sofia/internal/sip:+491234765${destination_number}${regex(${sofia_contact(10000@10.10.10.1)}|^[^@]+(.*)|%1)}
I hope someone see my mistake. i can not find the error. I tried with bypass media
on the 10000 extension, but with no real success. if i call from outside to internal
extension, i got sound with bypass media... but only in that case..
Here the complete LOG of that call...
And i see, that there is one rtp stream with the publy ip... why?
This call is complete internal...
To pass the zyxel, i neet the full number with country code an area code...
but always in the internal profile...
i need your help...
Country Code +49
Area Code 1234
Base Number 765
Call the 210 from phone nr 6:
2021-03-29 01:45:47.461232 [NOTICE] switch_channel.c:1118 New Channel sofia/internal/6@10.10.10.1:5060 [a4a2be42-08ef-4e27-8f8c-2a5b51be8be7]
2021-03-29 01:45:47.461232 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/6@10.10.10.1:5060) Running State Change CS_NEW (Cur 1 Tot 4345)
2021-03-29 01:45:47.461232 [DEBUG] sofia.c:10280 sofia/internal/6@10.10.10.1:5060 receiving invite from 10.10.10.243:5060 version: 1.10.5 -release-17-25569c1631 64bit
2021-03-29 01:45:47.461232 [DEBUG] sofia.c:10374 verifying acl "domains" for ip/port 10.10.10.243:0.
2021-03-29 01:45:47.461232 [WARNING] sofia_reg.c:1794 SIP auth challenge (INVITE) on sofia profile 'internal' for [210@10.10.10.1] from ip 10.10.10.243
2021-03-29 01:45:47.461232 [DEBUG] switch_core_state_machine.c:604 (sofia/internal/6@10.10.10.1:5060) State NEW
2021-03-29 01:45:47.461232 [DEBUG] sofia.c:2434 detaching session a4a2be42-08ef-4e27-8f8c-2a5b51be8be7
2021-03-29 01:45:47.541231 [DEBUG] sofia.c:2544 Re-attaching to session a4a2be42-08ef-4e27-8f8c-2a5b51be8be7
2021-03-29 01:45:47.541231 [DEBUG] sofia.c:10280 sofia/internal/6@10.10.10.1:5060 receiving invite from 10.10.10.243:5060 version: 1.10.5 -release-17-25569c1631 64bit
2021-03-29 01:45:47.541231 [DEBUG] sofia.c:10374 verifying acl "domains" for ip/port 10.10.10.243:0.
2021-03-29 01:45:47.561222 [DEBUG] sofia.c:7326 Channel sofia/internal/6@10.10.10.1:5060 entering state [received][100]
2021-03-29 01:45:47.561222 [DEBUG] sofia.c:7336 Remote SDP:
v=0
o=- 20046 20046 IN IP4 10.10.10.243
s=SDP data
c=IN IP4 10.10.10.243
t=0 0
m=audio 12332 RTP/AVP 9 0 8 18 101
a=rtpmap:9 G722/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
2021-03-29 01:45:47.561222 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [G722:9:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2021-03-29 01:45:47.561222 [DEBUG] switch_core_media.c:5649 Audio Codec Compare [G722:9:8000:20:64000:1] ++++ is saved as a match
2021-03-29 01:45:47.561222 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [G722:9:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2021-03-29 01:45:47.561222 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [G722:9:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2021-03-29 01:45:47.561222 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2021-03-29 01:45:47.561222 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2021-03-29 01:45:47.561222 [DEBUG] switch_core_media.c:5649 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
2021-03-29 01:45:47.561222 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2021-03-29 01:45:47.561222 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2021-03-29 01:45:47.561222 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2021-03-29 01:45:47.561222 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2021-03-29 01:45:47.561222 [DEBUG] switch_core_media.c:5649 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
2021-03-29 01:45:47.561222 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [G729:18:8000:20:8000:1]/[G722:9:8000:20:64000:1]
2021-03-29 01:45:47.561222 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMU:0:8000:20:64000:1]
2021-03-29 01:45:47.561222 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMA:8:8000:20:64000:1]
2021-03-29 01:45:47.561222 [DEBUG] switch_core_media.c:5510 Set telephone-event payload to 101@8000
2021-03-29 01:45:47.561222 [DEBUG] switch_core_media.c:3839 Set Codec sofia/internal/6@10.10.10.1:5060 G722/8000 20 ms 160 samples 64000 bits 1 channels
2021-03-29 01:45:47.561222 [DEBUG] switch_core_codec.c:111 sofia/internal/6@10.10.10.1:5060 Original read codec set to G722:9
2021-03-29 01:45:47.561222 [DEBUG] switch_core_media.c:5853 Set telephone-event payload to 101@8000
2021-03-29 01:45:47.561222 [DEBUG] switch_core_media.c:5911 sofia/internal/6@10.10.10.1:5060 Set 2833 dtmf send payload to 101 recv payload to 101
2021-03-29 01:45:47.561222 [DEBUG] sofia.c:7760 (sofia/internal/6@10.10.10.1:5060) State Change CS_NEW -> CS_INIT
2021-03-29 01:45:47.561222 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/6@10.10.10.1:5060) Running State Change CS_INIT (Cur 1 Tot 4345)
2021-03-29 01:45:47.561222 [DEBUG] switch_core_state_machine.c:628 (sofia/internal/6@10.10.10.1:5060) State INIT
2021-03-29 01:45:47.561222 [DEBUG] mod_sofia.c:93 sofia/internal/6@10.10.10.1:5060 SOFIA INIT
2021-03-29 01:45:47.561222 [DEBUG] switch_core_state_machine.c:40 sofia/internal/6@10.10.10.1:5060 Standard INIT
2021-03-29 01:45:47.561222 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/6@10.10.10.1:5060) State Change CS_INIT -> CS_ROUTING
2021-03-29 01:45:47.561222 [DEBUG] switch_core_state_machine.c:628 (sofia/internal/6@10.10.10.1:5060) State INIT going to sleep
2021-03-29 01:45:47.561222 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/6@10.10.10.1:5060) Running State Change CS_ROUTING (Cur 1 Tot 4345)
2021-03-29 01:45:47.561222 [DEBUG] switch_channel.c:2332 (sofia/internal/6@10.10.10.1:5060) Callstate Change DOWN -> RINGING
2021-03-29 01:45:47.561222 [DEBUG] switch_core_state_machine.c:644 (sofia/internal/6@10.10.10.1:5060) State ROUTING
2021-03-29 01:45:47.561222 [DEBUG] mod_sofia.c:154 sofia/internal/6@10.10.10.1:5060 SOFIA ROUTING
2021-03-29 01:45:47.561222 [DEBUG] switch_core_state_machine.c:236 sofia/internal/6@10.10.10.1:5060 Standard ROUTING
2021-03-29 01:45:47.561222 [INFO] mod_dialplan_xml.c:637 Processing 6 <6>->210 in context 10.10.10.1
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->user_exists] continue=true
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [user_exists] ${loopback_leg}() =~ /^B$/ break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (PASS) [user_exists] () =~ // break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
EXECUTE [depth=0] sofia/internal/6@10.10.10.1:5060 set(user_exists=false)
2021-03-29 01:45:47.561222 [DEBUG] mod_dptools.c:1672 SET sofia/internal/6@10.10.10.1:5060 [user_exists]=[false]
Dialplan: sofia/internal/6@10.10.10.1:5060 Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
EXECUTE [depth=0] sofia/internal/6@10.10.10.1:5060 set(from_user_exists=true)
2021-03-29 01:45:47.561222 [DEBUG] mod_dptools.c:1672 SET sofia/internal/6@10.10.10.1:5060 [from_user_exists]=[true]
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->caller-details] continue=true
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 Action set(caller_destination=${destination_number}) INLINE
EXECUTE [depth=0] sofia/internal/6@10.10.10.1:5060 set(caller_destination=210)
2021-03-29 01:45:47.561222 [DEBUG] mod_dptools.c:1672 SET sofia/internal/6@10.10.10.1:5060 [caller_destination]=[210]
Dialplan: sofia/internal/6@10.10.10.1:5060 Action set(caller_id_name=${caller_id_name}) INLINE
EXECUTE [depth=0] sofia/internal/6@10.10.10.1:5060 set(caller_id_name=6)
2021-03-29 01:45:47.561222 [DEBUG] mod_dptools.c:1672 SET sofia/internal/6@10.10.10.1:5060 [caller_id_name]=[6]
Dialplan: sofia/internal/6@10.10.10.1:5060 Action set(caller_id_number=${caller_id_number})
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->call-direction] continue=true
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 ANTI-Action export(call_direction=local) INLINE
EXECUTE [depth=0] sofia/internal/6@10.10.10.1:5060 export(call_direction=local)
2021-03-29 01:45:47.561222 [DEBUG] switch_channel.c:1310 EXPORT (export_vars) [call_direction]=[local]
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->global-variables] continue=true
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (PASS) [global-variables] () =~ // break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->domain-variables] continue=true
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (PASS) [domain-variables] () =~ // break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 Action export(origination_callee_id_name=${destination_number})
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->is_loopback] continue=true
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [is_loopback] ${is_follow_me_loopback}() =~ /true/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->user_record] continue=true
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 Action set(from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}) INLINE
EXECUTE [depth=0] sofia/internal/6@10.10.10.1:5060 set(from_user_record=)
2021-03-29 01:45:47.561222 [DEBUG] mod_dptools.c:1672 SET sofia/internal/6@10.10.10.1:5060 [from_user_record]=[UNDEF]
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->rtp_has_crypto] continue=true
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [rtp_has_crypto] ${rtp_has_crypto}() =~ /^(AEAD_AES_256_GCM_8|AEAD_AES_128_GCM_8|AES_CM_256_HMAC_SHA1_80|AES_CM_192_HMAC_SHA1_80|AES_CM_128_HMAC_SHA1_80|AES_CM_256_HMAC_SHA1_32|AES_CM_192_HMAC_SHA1_32|AES_CM_128_HMAC_SHA1_32|AES_CM_128_NULL_AUTH)$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->redial] continue=true
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [redial] destination_number(210) =~ /^(redial|\*870)$/ break=on-true
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (PASS) [redial] () =~ // break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->speed_dial] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [speed_dial] destination_number(210) =~ /^\*0(.*)$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->user_hold_music] continue=true
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [user_hold_music] ${hold_music}(local_stream://default) =~ /^$/ break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [user_hold_music] ${user_exists}(false) =~ /true/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->default_caller_id] continue=true
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (PASS) [default_caller_id] ${emergency_caller_id_name}() =~ /^$/ break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
EXECUTE [depth=0] sofia/internal/6@10.10.10.1:5060 set(emergency_caller_id_name=)
2021-03-29 01:45:47.561222 [DEBUG] mod_dptools.c:1672 SET sofia/internal/6@10.10.10.1:5060 [emergency_caller_id_name]=[UNDEF]
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
EXECUTE [depth=0] sofia/internal/6@10.10.10.1:5060 set(emergency_caller_id_number=)
2021-03-29 01:45:47.561222 [DEBUG] mod_dptools.c:1672 SET sofia/internal/6@10.10.10.1:5060 [emergency_caller_id_number]=[UNDEF]
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (PASS) [default_caller_id] ${outbound_caller_id_name}() =~ /^$/ break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 Action set(outbound_caller_id_name=${default_outbound_caller_id_name}) INLINE
EXECUTE [depth=0] sofia/internal/6@10.10.10.1:5060 set(outbound_caller_id_name=)
2021-03-29 01:45:47.561222 [DEBUG] mod_dptools.c:1672 SET sofia/internal/6@10.10.10.1:5060 [outbound_caller_id_name]=[UNDEF]
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [default_caller_id] ${outbound_caller_id_number}(+4912347656) =~ /^$/ break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->OldPBX2NewInternal] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [OldPBX2NewInternal] caller_id_number(6) =~ /^10000$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->sip-trunk.telekom.de_0+] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (PASS) [sip-trunk.telekom.de_0+] ${user_exists}(false) =~ /false/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [sip-trunk.telekom.de_0+] destination_number(210) =~ /^0(\+\d{4,15})$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->RingGroup666] continue=
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [RingGroup666] destination_number(210) =~ /^666$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->agent_status] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [agent_status] destination_number(210) =~ /^\*22$/ break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [agent_status] destination_number(210) =~ /^(agent\+)(.*)$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->agent_status_id] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [agent_status_id] destination_number(210) =~ /^\*23$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->group-intercept] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [group-intercept] destination_number(210) =~ /^\*8$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->page-extension] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [page-extension] destination_number(210) =~ /^\*8(\d{2,7})$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->eavesdrop] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [eavesdrop] destination_number(210) =~ /^\*33(\d{2,7})$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->call_privacy] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [call_privacy] destination_number(210) =~ /^\*67(\d+)$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->call_return] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [call_return] destination_number(210) =~ /^\*69$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->extension_queue] continue=
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [extension_queue] destination_number(210) =~ /^\*800(.*)$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->intercept-ext-polycom] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [intercept-ext-polycom] destination_number(210) =~ /^\*97(\d+)$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->intercept-ext] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [intercept-ext] destination_number(210) =~ /^\*\*(\d+)$/ break=on-true
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [intercept-ext] destination_number(210) =~ /^\*\*$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->dx] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [dx] destination_number(210) =~ /^dx$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->send_to_voicemail] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [send_to_voicemail] destination_number(210) =~ /^\*99(\d{2,10})$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->att_xfer] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [att_xfer] destination_number(210) =~ /^att_xfer$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->extension-to-voicemail] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [extension-to-voicemail] ${user_exists}(false) =~ /^true$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->vmain_myuser] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [vmain_myuser] destination_number(210) =~ /^\*100$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->xfer_vm] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [xfer_vm] destination_number(210) =~ /^xfer_vm$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->vmain] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [vmain] destination_number(210) =~ /^vmain$|^\*4000$|^\*98$/ break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [vmain] destination_number(210) =~ /^(vmain$|^\*4000$|^\*98)(\d{2,12})$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->vmain_user] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [vmain_user] destination_number(210) =~ /^\*97$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->is_transfer] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [is_transfer] destination_number(210) =~ /^is_transfer$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->cf] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [cf] destination_number(210) =~ /^cf$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->delay_echo] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [delay_echo] destination_number(210) =~ /^\*9195$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->echo] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [echo] destination_number(210) =~ /^\*9196$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->is_zrtp_secure] continue=true
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [is_zrtp_secure] ${zrtp_secure_media_confirmed}() =~ /^true$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 ANTI-Action eval(not_secure)
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->milliwatt] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [milliwatt] destination_number(210) =~ /^\*9197$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->tone_stream] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [tone_stream] destination_number(210) =~ /^\*9198$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->is_secure] continue=true
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [is_secure] ${sip_via_protocol}(udp) =~ /tls/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->hold_music] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [hold_music] destination_number(210) =~ /^\*9664$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->recordings] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [recordings] destination_number(210) =~ /^\*(732)$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->directory] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [directory] destination_number(210) =~ /^\*411$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->wake-up] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [wake-up] destination_number(210) =~ /^\*(925)$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->valet_park] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [valet_park] destination_number(210) =~ /^(park\+)?\*(59[0-9][0-9])$/ break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [valet_park] ${sip_h_Referred-By}() =~ /sip:(.*)@.*/ break=never
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [valet_park] destination_number(210) =~ /^(park\+)?\*(59[0-9][0-9])$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->operator] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [operator] destination_number(210) =~ /^0$|^operator$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->operator-forward] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [operator-forward] destination_number(210) =~ /^\*000$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->do-not-disturb] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [do-not-disturb] destination_number(210) =~ /^\*77$/ break=on-true
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [do-not-disturb] destination_number(210) =~ /^\*78$|\*363$/ break=on-true
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [do-not-disturb] destination_number(210) =~ /^\*79$/ break=on-true
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [do-not-disturb] destination_number(210) =~ /^dnd\+6$/ break=on-true
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->call_screen] continue=true
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [call_screen] ${call_screen_enabled}(false) =~ /^true$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->follow-me-destinations] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [follow-me-destinations] ${user_exists}(false) =~ /^true$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->call-forward] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [call-forward] destination_number(210) =~ /^\*72(\d*)$/ break=on-true
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [call-forward] destination_number(210) =~ /^\*73$/ break=on-true
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [call-forward] destination_number(210) =~ /^\*74$/ break=on-true
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [call-forward] destination_number(210) =~ /^forward\+(\Q6\E)(?:\/(\d+))?$/ break=on-true
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->call-forward-all] continue=
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [call-forward-all] ${user_exists}(false) =~ /true/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->call-forward-not-registered] continue=
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [call-forward-not-registered] ${user_exists}(false) =~ /true/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->follow-me] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [follow-me] destination_number(210) =~ /^\*21$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->clear_sip_auto_answer] continue=true
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [clear_sip_auto_answer] ${click_to_call}() =~ /true/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->talking clock date and time] continue=
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [talking clock date and time] destination_number(210) =~ /^\*9172$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->talking clock time] continue=
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [talking clock time] destination_number(210) =~ /^\*9170$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->talking clock date] continue=
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [talking clock date] destination_number(210) =~ /^\*9171$/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->local_extension_old] continue=true
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (PASS) [local_extension_old] ${user_exists}(false) =~ /false/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 Action export(dialed_extension=${destination_number}) INLINE
EXECUTE [depth=0] sofia/internal/6@10.10.10.1:5060 export(dialed_extension=210)
2021-03-29 01:45:47.561222 [DEBUG] switch_channel.c:1310 EXPORT (export_vars) [dialed_extension]=[210]
Dialplan: sofia/internal/6@10.10.10.1:5060 Action limit(hash ${domain_name} ${destination_number} ${limit_max} ${limit_destination})
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (PASS) [local_extension_old] () =~ // break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 Action set(hangup_after_bridge=true)
Dialplan: sofia/internal/6@10.10.10.1:5060 Action set(continue_on_fail=true)
Dialplan: sofia/internal/6@10.10.10.1:5060 Action hash(insert/${domain_name}-call_return/${dialed_extension}/${caller_id_number})
Dialplan: sofia/internal/6@10.10.10.1:5060 Action hash(insert/${domain_name}-last_dial_ext/${dialed_extension}/${uuid})
Dialplan: sofia/internal/6@10.10.10.1:5060 Action set(called_party_call_group=${user_data(${dialed_extension}@${domain_name} var call_group)})
Dialplan: sofia/internal/6@10.10.10.1:5060 Action hash(insert/${domain_name}-last_dial/${called_party_call_group}/${uuid})
Dialplan: sofia/internal/6@10.10.10.1:5060 Action set(api_hangup_hook=lua app.lua hangup)
Dialplan: sofia/internal/6@10.10.10.1:5060 Action export(domain_name=${domain_name})
Dialplan: sofia/internal/6@10.10.10.1:5060 Action bridge(sofia/internal/sip:+491234765${destination_number}${regex(${sofia_contact(10000@10.10.10.1)}|^[^@]+(.*)|%1)})
Dialplan: sofia/internal/6@10.10.10.1:5060 Action lua(app.lua failure_handler)
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->local_extension] continue=true
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [local_extension] ${user_exists}(false) =~ /true/ break=on-false
Dialplan: sofia/internal/6@10.10.10.1:5060 parsing [10.10.10.1->voicemail] continue=false
Dialplan: sofia/internal/6@10.10.10.1:5060 Regex (FAIL) [voicemail] ${user_exists}(false) =~ /true/ break=on-false
2021-03-29 01:45:47.561222 [DEBUG] switch_core_state_machine.c:287 (sofia/internal/6@10.10.10.1:5060) State Change CS_ROUTING -> CS_EXECUTE
2021-03-29 01:45:47.561222 [DEBUG] switch_core_state_machine.c:644 (sofia/internal/6@10.10.10.1:5060) State ROUTING going to sleep
2021-03-29 01:45:47.561222 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/6@10.10.10.1:5060) Running State Change CS_EXECUTE (Cur 1 Tot 4345)
2021-03-29 01:45:47.561222 [DEBUG] switch_core_state_machine.c:651 (sofia/internal/6@10.10.10.1:5060) State EXECUTE
2021-03-29 01:45:47.561222 [DEBUG] mod_sofia.c:209 sofia/internal/6@10.10.10.1:5060 SOFIA EXECUTE
2021-03-29 01:45:47.561222 [DEBUG] switch_core_state_machine.c:329 sofia/internal/6@10.10.10.1:5060 Standard EXECUTE
EXECUTE [depth=0] sofia/internal/6@10.10.10.1:5060 set(caller_id_number=6)
2021-03-29 01:45:47.561222 [DEBUG] mod_dptools.c:1672 SET sofia/internal/6@10.10.10.1:5060 [caller_id_number]=[6]
EXECUTE [depth=0] sofia/internal/6@10.10.10.1:5060 set(RFC2822_DATE=Mon, 29 Mar 2021 01:45:47 +0200)
2021-03-29 01:45:47.561222 [DEBUG] mod_dptools.c:1672 SET sofia/internal/6@10.10.10.1:5060 [RFC2822_DATE]=[Mon, 29 Mar 2021 01:45:47 +0200]
EXECUTE [depth=0] sofia/internal/6@10.10.10.1:5060 export(origination_callee_id_name=210)
2021-03-29 01:45:47.561222 [DEBUG] switch_channel.c:1310 EXPORT (export_vars) [origination_callee_id_name]=[210]
EXECUTE [depth=0] sofia/internal/6@10.10.10.1:5060 hash(insert/10.10.10.1-last_dial/6/210)
EXECUTE [depth=0] sofia/internal/6@10.10.10.1:5060 eval(not_secure)
EXECUTE [depth=0] sofia/internal/6@10.10.10.1:5060 limit(hash 10.10.10.1 210 5 error/user_busy)
2021-03-29 01:45:47.561222 [DEBUG] switch_limit.c:124 incr called: 10.10.10.1_210 max:5, interval:0
2021-03-29 01:45:47.561222 [DEBUG] mod_hash.c:196 Usage for 10.10.10.1_210 is now 1/5
EXECUTE [depth=0] sofia/internal/6@10.10.10.1:5060 set(hangup_after_bridge=true)
2021-03-29 01:45:47.561222 [DEBUG] mod_dptools.c:1672 SET sofia/internal/6@10.10.10.1:5060 [hangup_after_bridge]=[true]
EXECUTE [depth=0] sofia/internal/6@10.10.10.1:5060 set(continue_on_fail=true)
2021-03-29 01:45:47.561222 [DEBUG] mod_dptools.c:1672 SET sofia/internal/6@10.10.10.1:5060 [continue_on_fail]=[true]
EXECUTE [depth=0] sofia/internal/6@10.10.10.1:5060 hash(insert/10.10.10.1-call_return/210/6)
EXECUTE [depth=0] sofia/internal/6@10.10.10.1:5060 hash(insert/10.10.10.1-last_dial_ext/210/a4a2be42-08ef-4e27-8f8c-2a5b51be8be7)
EXECUTE [depth=0] sofia/internal/6@10.10.10.1:5060 set(called_party_call_group=)
2021-03-29 01:45:47.561222 [DEBUG] mod_dptools.c:1672 SET sofia/internal/6@10.10.10.1:5060 [called_party_call_group]=[UNDEF]
EXECUTE [depth=0] sofia/internal/6@10.10.10.1:5060 hash(insert/10.10.10.1-last_dial//a4a2be42-08ef-4e27-8f8c-2a5b51be8be7)
EXECUTE [depth=0] sofia/internal/6@10.10.10.1:5060 set(api_hangup_hook=lua app.lua hangup)
2021-03-29 01:45:47.561222 [DEBUG] mod_dptools.c:1672 SET sofia/internal/6@10.10.10.1:5060 [api_hangup_hook]=[lua app.lua hangup]
EXECUTE [depth=0] sofia/internal/6@10.10.10.1:5060 export(domain_name=10.10.10.1)
2021-03-29 01:45:47.561222 [DEBUG] switch_channel.c:1310 EXPORT (export_vars) [domain_name]=[10.10.10.1]
EXECUTE [depth=0] sofia/internal/6@10.10.10.1:5060 bridge(sofia/internal/sip:+491234765210@192.168.115.81:5070;line=c25ef1127cf24d1;fs_nat=yes;fs_path=sip%3A10000%40192.168.115.81%3A5070%3Bline%3Dc25ef1127cf24d1)
2021-03-29 01:45:47.561222 [DEBUG] switch_channel.c:1264 sofia/internal/6@10.10.10.1:5060 EXPORTING[export_vars] [domain_name]=[10.10.10.1] to event
2021-03-29 01:45:47.561222 [DEBUG] switch_channel.c:1264 sofia/internal/6@10.10.10.1:5060 EXPORTING[export_vars] [call_direction]=[local] to event
2021-03-29 01:45:47.561222 [DEBUG] switch_channel.c:1264 sofia/internal/6@10.10.10.1:5060 EXPORTING[export_vars] [dialed_extension]=[210] to event
2021-03-29 01:45:47.561222 [DEBUG] switch_channel.c:1264 sofia/internal/6@10.10.10.1:5060 EXPORTING[export_vars] [origination_callee_id_name]=[210] to event
2021-03-29 01:45:47.561222 [DEBUG] switch_ivr_originate.c:2242 Parsing global variables
2021-03-29 01:45:47.561222 [NOTICE] switch_channel.c:1118 New Channel sofia/internal/%2B491234765210@192.168.115.81:5070 [1a1c24a6-9b5b-479f-8513-31c26a709cf5]
2021-03-29 01:45:47.561222 [DEBUG] mod_sofia.c:5089 (sofia/internal/%2B491234765210@192.168.115.81:5070) State Change CS_NEW -> CS_INIT
2021-03-29 01:45:47.561222 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/%2B491234765210@192.168.115.81:5070) Running State Change CS_INIT (Cur 2 Tot 4346)
2021-03-29 01:45:47.561222 [DEBUG] switch_core_state_machine.c:628 (sofia/internal/%2B491234765210@192.168.115.81:5070) State INIT
2021-03-29 01:45:47.561222 [DEBUG] mod_sofia.c:93 sofia/internal/%2B491234765210@192.168.115.81:5070 SOFIA INIT
2021-03-29 01:45:47.561222 [DEBUG] sofia_glue.c:1587 sip:10000@192.168.115.81:5070;line=c25ef1127cf24d1 Setting proxy route to sofia/internal/%2B491234765210@192.168.115.81:5070
2021-03-29 01:45:47.561222 [DEBUG] sofia_glue.c:1618 sofia/internal/%2B491234765210@192.168.115.81:5070 sending invite version: 1.10.5 -release-17-25569c1631 64bit
Local SDP:
v=0
o=FreeSWITCH 1616950895 1616950896 IN IP4 92.1.2.3
s=FreeSWITCH
c=IN IP4 93.241.215.252
t=0 0
m=audio 24252 RTP/AVP 9 0 8 101 13
a=fmtp:101 0-16
a=rtpmap:13 CN/8000
a=ptime:20
a=sendrecv
2021-03-29 01:45:47.561222 [DEBUG] switch_core_state_machine.c:40 sofia/internal/%2B491234765210@192.168.115.81:5070 Standard INIT
2021-03-29 01:45:47.561222 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/%2B491234765210@192.168.115.81:5070) State Change CS_INIT -> CS_ROUTING
2021-03-29 01:45:47.561222 [DEBUG] switch_core_state_machine.c:628 (sofia/internal/%2B491234765210@192.168.115.81:5070) State INIT going to sleep
2021-03-29 01:45:47.561222 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/%2B491234765210@192.168.115.81:5070) Running State Change CS_ROUTING (Cur 2 Tot 4346)
2021-03-29 01:45:47.561222 [DEBUG] switch_core_state_machine.c:644 (sofia/internal/%2B491234765210@192.168.115.81:5070) State ROUTING
2021-03-29 01:45:47.561222 [DEBUG] mod_sofia.c:154 sofia/internal/%2B491234765210@192.168.115.81:5070 SOFIA ROUTING
2021-03-29 01:45:47.561222 [DEBUG] switch_ivr_originate.c:67 (sofia/internal/%2B491234765210@192.168.115.81:5070) State Change CS_ROUTING -> CS_CONSUME_MEDIA
2021-03-29 01:45:47.561222 [DEBUG] switch_core_state_machine.c:644 (sofia/internal/%2B491234765210@192.168.115.81:5070) State ROUTING going to sleep
2021-03-29 01:45:47.561222 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/%2B491234765210@192.168.115.81:5070) Running State Change CS_CONSUME_MEDIA (Cur 2 Tot 4346)
2021-03-29 01:45:47.561222 [DEBUG] switch_core_state_machine.c:663 (sofia/internal/%2B491234765210@192.168.115.81:5070) State CONSUME_MEDIA
2021-03-29 01:45:47.561222 [DEBUG] switch_core_state_machine.c:663 (sofia/internal/%2B491234765210@192.168.115.81:5070) State CONSUME_MEDIA going to sleep
2021-03-29 01:45:47.561222 [DEBUG] sofia.c:7326 Channel sofia/internal/%2B491234765210@192.168.115.81:5070 entering state [calling][0]
2021-03-29 01:45:47.761221 [DEBUG] sofia.c:7326 Channel sofia/internal/%2B491234765210@192.168.115.81:5070 entering state [proceeding][180]
2021-03-29 01:45:47.761221 [NOTICE] sofia.c:7437 Ring-Ready sofia/internal/%2B491234765210@192.168.115.81:5070!
2021-03-29 01:45:47.761221 [DEBUG] switch_channel.c:3437 (sofia/internal/%2B491234765210@192.168.115.81:5070) Callstate Change DOWN -> RINGING
2021-03-29 01:45:47.781229 [INFO] switch_ivr_originate.c:1275 Sending early media
2021-03-29 01:45:47.781229 [DEBUG] switch_core_media.c:8663 AUDIO RTP [sofia/internal/6@10.10.10.1:5060] 10.10.10.1 port 29870 -> 10.10.10.243 port 12332 codec: 9 ms: 20
2021-03-29 01:45:47.781229 [DEBUG] switch_rtp.c:4450 Starting timer [soft] 160 bytes per 20ms
2021-03-29 01:45:47.781229 [DEBUG] switch_core_media.c:8977 sofia/internal/6@10.10.10.1:5060 Set 2833 dtmf send payload to 101
2021-03-29 01:45:47.781229 [DEBUG] switch_core_media.c:8984 sofia/internal/6@10.10.10.1:5060 Set 2833 dtmf receive payload to 101
2021-03-29 01:45:47.781229 [DEBUG] switch_core_media.c:9007 sofia/internal/6@10.10.10.1:5060 Set rtp dtmf delay to 40
2021-03-29 01:45:47.781229 [DEBUG] mod_sofia.c:2593 Ring SDP:
v=0
o=FreeSWITCH 1616945277 1616945278 IN IP4 10.10.10.1
s=FreeSWITCH
c=IN IP4 10.10.10.1
t=0 0
m=audio 29870 RTP/AVP 9 101
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
2021-03-29 01:45:47.781229 [NOTICE] mod_sofia.c:2596 Pre-Answer sofia/internal/6@10.10.10.1:5060!
2021-03-29 01:45:47.781229 [DEBUG] switch_channel.c:3565 (sofia/internal/6@10.10.10.1:5060) Callstate Change RINGING -> EARLY
2021-03-29 01:45:47.781229 [DEBUG] switch_ivr_originate.c:1333 Raw Codec Activation Success L16@16000hz 1 channel 20ms
2021-03-29 01:45:47.781229 [DEBUG] switch_core_codec.c:223 sofia/internal/6@10.10.10.1:5060 Push codec L16:100
2021-03-29 01:45:47.781229 [DEBUG] switch_ivr_originate.c:1407 Play Ringback Tone [%(1000,4000,425)]
2021-03-29 01:45:47.801230 [DEBUG] sofia.c:7326 Channel sofia/internal/6@10.10.10.1:5060 entering state [early][183]
2021-03-29 01:45:47.981236 [DEBUG] switch_rtp.c:7759 Correct audio ip/port confirmed.
freeswitch@vmPBX1> Ringing, then active:
-ERR Ringing, then active: Command not found!
freeswitch@vmPBX1>
2021-03-29 01:45:53.821200 [DEBUG] sofia.c:7326 Channel sofia/internal/%2B491234765210@192.168.115.81:5070 entering state [completing][200]
2021-03-29 01:45:53.821200 [DEBUG] sofia.c:7336 Remote SDP:
v=0
o=10000 1616975146 1616975147 IN IP4 192.168.115.81
s=-
c=IN IP4 192.168.115.81
t=0 0
m=audio 16386 RTP/AVP 8
a=rtcp:16387
2021-03-29 01:45:53.821200 [DEBUG] sofia.c:7326 Channel sofia/internal/%2B491234765210@192.168.115.81:5070 entering state [ready][200]
2021-03-29 01:45:53.821200 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2021-03-29 01:45:53.821200 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2021-03-29 01:45:53.821200 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2021-03-29 01:45:53.821200 [DEBUG] switch_core_media.c:5649 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
2021-03-29 01:45:53.821200 [DEBUG] switch_core_media.c:3839 Set Codec sofia/internal/%2B491234765210@192.168.115.81:5070 PCMA/8000 20 ms 160 samples 64000 bits 1 channels
2021-03-29 01:45:53.821200 [DEBUG] switch_core_codec.c:111 sofia/internal/%2B491234765210@192.168.115.81:5070 Original read codec set to PCMA:8
2021-03-29 01:45:53.821200 [DEBUG] switch_core_media.c:5918 No 2833 in SDP. Disable 2833 dtmf and switch to INFO
2021-03-29 01:45:53.821200 [DEBUG] switch_core_media.c:8663 AUDIO RTP [sofia/internal/%2B491234765210@192.168.115.81:5070] 10.10.10.1 port 24252 -> 192.168.115.81 port 16386 codec: 8 ms: 20
2021-03-29 01:45:53.821200 [DEBUG] switch_rtp.c:4450 Starting timer [soft] 160 bytes per 20ms
2021-03-29 01:45:53.821200 [DEBUG] switch_core_media.c:8885 Activating RTCP PORT 16387
2021-03-29 01:45:53.821200 [DEBUG] switch_rtp.c:4848 RTCP send rate is: 1000 and packet rate is: 20000 Remote Port: 16387
2021-03-29 01:45:53.821200 [DEBUG] switch_rtp.c:2636 Setting RTCP remote addr to 192.168.115.81:16387 2
2021-03-29 01:45:53.821200 [DEBUG] switch_core_media.c:9007 sofia/internal/%2B491234765210@192.168.115.81:5070 Set rtp dtmf delay to 40
2021-03-29 01:45:53.821200 [NOTICE] sofia.c:8504 Channel [sofia/internal/%2B491234765210@192.168.115.81:5070] has been answered
2021-03-29 01:45:53.821200 [DEBUG] switch_channel.c:3865 (sofia/internal/%2B491234765210@192.168.115.81:5070) Callstate Change RINGING -> ACTIVE
2021-03-29 01:45:53.841226 [DEBUG] switch_core_codec.c:248 sofia/internal/6@10.10.10.1:5060 Restore previous codec G722:9.
2021-03-29 01:45:53.841226 [DEBUG] switch_core_media.c:8645 Audio params are unchanged for sofia/internal/6@10.10.10.1:5060.
2021-03-29 01:45:53.841226 [DEBUG] mod_sofia.c:898 Local SDP sofia/internal/6@10.10.10.1:5060:
v=0
o=FreeSWITCH 1616945277 1616945279 IN IP4 10.10.10.1
s=FreeSWITCH
c=IN IP4 10.10.10.1
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
2021-03-29 01:45:53.841226 [NOTICE] switch_ivr_originate.c:3794 Channel [sofia/internal/6@10.10.10.1:5060] has been answered
2021-03-29 01:45:53.841226 [DEBUG] switch_channel.c:3865 (sofia/internal/6@10.10.10.1:5060) Callstate Change EARLY -> ACTIVE
2021-03-29 01:45:53.841226 [DEBUG] sofia.c:7326 Channel sofia/internal/6@10.10.10.1:5060 entering state [completed][200]
2021-03-29 01:45:53.841226 [DEBUG] switch_ivr_originate.c:3852 Originate Resulted in Success: [sofia/internal/%2B491234765210@192.168.115.81:5070]
2021-03-29 01:45:53.841226 [DEBUG] switch_ivr_bridge.c:1793 (sofia/internal/%2B491234765210@192.168.115.81:5070) State Change CS_CONSUME_MEDIA -> CS_EXCHANGE_MEDIA
2021-03-29 01:45:53.841226 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/%2B491234765210@192.168.115.81:5070) Running State Change CS_EXCHANGE_MEDIA (Cur 2 Tot 4346)
2021-03-29 01:45:53.841226 [DEBUG] switch_core_state_machine.c:654 (sofia/internal/%2B491234765210@192.168.115.81:5070) State EXCHANGE_MEDIA
2021-03-29 01:45:53.841226 [DEBUG] mod_sofia.c:656 SOFIA EXCHANGE_MEDIA
2021-03-29 01:45:53.901230 [DEBUG] switch_rtp.c:7759 Correct audio ip/port confirmed.
2021-03-29 01:45:53.901230 [NOTICE] switch_core_media.c:15845 Activating write resampler
2021-03-29 01:45:54.401232 [DEBUG] sofia.c:7326 Channel sofia/internal/6@10.10.10.1:5060 entering state [ready][200]
2021-03-29 01:45:54.441229 [DEBUG] sofia.c:7326 Channel sofia/internal/6@10.10.10.1:5060 entering state [calling][0]
2021-03-29 01:45:54.501230 [DEBUG] sofia.c:7326 Channel sofia/internal/6@10.10.10.1:5060 entering state [ready][200]
2021-03-29 01:45:54.501230 [DEBUG] sofia.c:7336 Remote SDP:
v=0
o=- 20046 20047 IN IP4 10.10.10.243
s=SDP data
t=0 0
m=audio 12332 RTP/AVP 9 101
a=fmtp:101 0-15
a=ptime:20
2021-03-29 01:45:54.501230 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [G722:9:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2021-03-29 01:45:54.501230 [DEBUG] switch_core_media.c:5649 Audio Codec Compare [G722:9:8000:20:64000:1] ++++ is saved as a match
2021-03-29 01:45:54.501230 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [G722:9:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2021-03-29 01:45:54.501230 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [G722:9:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2021-03-29 01:45:54.501230 [DEBUG] switch_core_media.c:5510 Set telephone-event payload to 101@8000
2021-03-29 01:45:54.501230 [DEBUG] switch_core_media.c:5853 Set telephone-event payload to 101@8000
2021-03-29 01:45:54.501230 [DEBUG] switch_core_media.c:5911 sofia/internal/6@10.10.10.1:5060 Set 2833 dtmf send payload to 101 recv payload to 101
2021-03-29 01:45:54.501230 [DEBUG] sofia.c:8345 Processing updated SDP
2021-03-29 01:45:54.501230 [DEBUG] switch_core_media.c:8645 Audio params are unchanged for sofia/internal/6@10.10.10.1:5060.
freeswitch@vmPBX1>
freeswitch@vmPBX1> Here the call is active, but no sound
freeswitch@vmPBX1>
freeswitch@vmPBX1> Now cancled the call on phone (after 32 seconds), but the call is still active... it cancled after a timout, arround one minute after call
freeswitch@vmPBX1>
2021-03-29 01:46:51.921230 [DEBUG] sofia.c:7326 Channel sofia/internal/%2B491234765210@192.168.115.81:5070 entering state [calling][0]
2021-03-29 01:46:51.921230 [DEBUG] sofia.c:7326 Channel sofia/internal/%2B491234765210@192.168.115.81:5070 entering state [terminating][481]
2021-03-29 01:46:51.921230 [NOTICE] sofia.c:8559 Hangup sofia/internal/%2B491234765210@192.168.115.81:5070 [CS_EXCHANGE_MEDIA] [NORMAL_TEMPORARY_FAILURE]
2021-03-29 01:46:51.921230 [DEBUG] switch_ivr_bridge.c:826 sofia/internal/%2B491234765210@192.168.115.81:5070 ending bridge by request from read function
2021-03-29 01:46:51.921230 [DEBUG] switch_ivr_bridge.c:912 BRIDGE THREAD DONE [sofia/internal/%2B491234765210@192.168.115.81:5070]
2021-03-29 01:46:51.921230 [DEBUG] switch_core_state_machine.c:654 (sofia/internal/%2B491234765210@192.168.115.81:5070) State EXCHANGE_MEDIA going to sleep
2021-03-29 01:46:51.921230 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/%2B491234765210@192.168.115.81:5070) Running State Change CS_HANGUP (Cur 2 Tot 4346)
2021-03-29 01:46:51.921230 [DEBUG] switch_core_state_machine.c:848 (sofia/internal/%2B491234765210@192.168.115.81:5070) Callstate Change ACTIVE -> HANGUP
2021-03-29 01:46:51.921230 [DEBUG] switch_core_state_machine.c:850 (sofia/internal/%2B491234765210@192.168.115.81:5070) State HANGUP
2021-03-29 01:46:51.921230 [DEBUG] mod_sofia.c:453 Channel sofia/internal/%2B491234765210@192.168.115.81:5070 hanging up, cause: NORMAL_TEMPORARY_FAILURE
2021-03-29 01:46:51.921230 [DEBUG] switch_core_state_machine.c:60 sofia/internal/%2B491234765210@192.168.115.81:5070 Standard HANGUP, cause: NORMAL_TEMPORARY_FAILURE
2021-03-29 01:46:51.921230 [DEBUG] switch_core_state_machine.c:850 (sofia/internal/%2B491234765210@192.168.115.81:5070) State HANGUP going to sleep
2021-03-29 01:46:51.921230 [DEBUG] switch_core_state_machine.c:620 (sofia/internal/%2B491234765210@192.168.115.81:5070) State Change CS_HANGUP -> CS_REPORTING
2021-03-29 01:46:51.921230 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/%2B491234765210@192.168.115.81:5070) Running State Change CS_REPORTING (Cur 2 Tot 4346)
2021-03-29 01:46:51.921230 [DEBUG] switch_core_state_machine.c:936 (sofia/internal/%2B491234765210@192.168.115.81:5070) State REPORTING
2021-03-29 01:46:51.921230 [DEBUG] switch_core_state_machine.c:174 sofia/internal/%2B491234765210@192.168.115.81:5070 Standard REPORTING, cause: NORMAL_TEMPORARY_FAILURE
2021-03-29 01:46:51.921230 [DEBUG] switch_core_state_machine.c:936 (sofia/internal/%2B491234765210@192.168.115.81:5070) State REPORTING going to sleep
2021-03-29 01:46:51.921230 [DEBUG] switch_core_state_machine.c:611 (sofia/internal/%2B491234765210@192.168.115.81:5070) State Change CS_REPORTING -> CS_DESTROY
2021-03-29 01:46:51.921230 [DEBUG] switch_core_session.c:1726 Session 4346 (sofia/internal/%2B491234765210@192.168.115.81:5070) Locked, Waiting on external entities
2021-03-29 01:46:51.941197 [DEBUG] switch_ivr_bridge.c:912 BRIDGE THREAD DONE [sofia/internal/6@10.10.10.1:5060]
2021-03-29 01:46:51.941197 [NOTICE] switch_ivr_bridge.c:1944 Hangup sofia/internal/6@10.10.10.1:5060 [CS_EXECUTE] [NORMAL_TEMPORARY_FAILURE]
2021-03-29 01:46:51.941197 [DEBUG] mod_hash.c:296 Usage for 10.10.10.1_210 is now 0
2021-03-29 01:46:51.941197 [NOTICE] switch_core_session.c:1744 Session 4346 (sofia/internal/%2B491234765210@192.168.115.81:5070) Ended
2021-03-29 01:46:51.941197 [NOTICE] switch_core_session.c:1748 Close Channel sofia/internal/%2B491234765210@192.168.115.81:5070 [CS_DESTROY]
2021-03-29 01:46:51.941197 [DEBUG] switch_core_session.c:2905 sofia/internal/6@10.10.10.1:5060 skip receive message [APPLICATION_EXEC_COMPLETE] (channel is hungup already)
2021-03-29 01:46:51.941197 [DEBUG] switch_core_state_machine.c:651 (sofia/internal/6@10.10.10.1:5060) State EXECUTE going to sleep
2021-03-29 01:46:51.941197 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/6@10.10.10.1:5060) Running State Change CS_HANGUP (Cur 1 Tot 4346)
2021-03-29 01:46:51.941197 [DEBUG] switch_core_state_machine.c:739 (sofia/internal/%2B491234765210@192.168.115.81:5070) Running State Change CS_DESTROY (Cur 1 Tot 4346)
2021-03-29 01:46:51.941197 [DEBUG] switch_core_state_machine.c:749 (sofia/internal/%2B491234765210@192.168.115.81:5070) State DESTROY
2021-03-29 01:46:51.941197 [DEBUG] mod_sofia.c:364 sofia/internal/%2B491234765210@192.168.115.81:5070 SOFIA DESTROY
2021-03-29 01:46:51.941197 [DEBUG] switch_core_state_machine.c:181 sofia/internal/%2B491234765210@192.168.115.81:5070 Standard DESTROY
2021-03-29 01:46:51.941197 [DEBUG] switch_core_state_machine.c:848 (sofia/internal/6@10.10.10.1:5060) Callstate Change ACTIVE -> HANGUP
2021-03-29 01:46:51.941197 [DEBUG] switch_core_state_machine.c:749 (sofia/internal/%2B491234765210@192.168.115.81:5070) State DESTROY going to sleep
2021-03-29 01:46:51.941197 [DEBUG] switch_core_state_machine.c:850 (sofia/internal/6@10.10.10.1:5060) State HANGUP
2021-03-29 01:46:51.941197 [DEBUG] mod_sofia.c:447 sofia/internal/6@10.10.10.1:5060 Overriding SIP cause 503 with 481 from the other leg
2021-03-29 01:46:51.941197 [DEBUG] mod_sofia.c:453 Channel sofia/internal/6@10.10.10.1:5060 hanging up, cause: NORMAL_TEMPORARY_FAILURE
2021-03-29 01:46:51.941197 [DEBUG] mod_sofia.c:507 Sending BYE to sofia/internal/6@10.10.10.1:5060
2021-03-29 01:46:51.941197 [DEBUG] switch_core_state_machine.c:60 sofia/internal/6@10.10.10.1:5060 Standard HANGUP, cause: NORMAL_TEMPORARY_FAILURE
2021-03-29 01:46:51.941197 [DEBUG] switch_core_state_machine.c:850 (sofia/internal/6@10.10.10.1:5060) State HANGUP going to sleep
2021-03-29 01:46:51.941197 [DEBUG] switch_core_state_machine.c:781 Hangup Command with no Session lua(app.lua hangup):
2021-03-29 01:46:51.941197 [DEBUG] switch_core_state_machine.c:620 (sofia/internal/6@10.10.10.1:5060) State Change CS_HANGUP -> CS_REPORTING
2021-03-29 01:46:51.941197 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/6@10.10.10.1:5060) Running State Change CS_REPORTING (Cur 1 Tot 4346)
2021-03-29 01:46:51.941197 [DEBUG] switch_core_state_machine.c:936 (sofia/internal/6@10.10.10.1:5060) State REPORTING
2021-03-29 01:46:51.961229 [DEBUG] switch_core_state_machine.c:174 sofia/internal/6@10.10.10.1:5060 Standard REPORTING, cause: NORMAL_TEMPORARY_FAILURE
2021-03-29 01:46:51.961229 [DEBUG] switch_core_state_machine.c:936 (sofia/internal/6@10.10.10.1:5060) State REPORTING going to sleep
2021-03-29 01:46:51.961229 [DEBUG] switch_core_state_machine.c:611 (sofia/internal/6@10.10.10.1:5060) State Change CS_REPORTING -> CS_DESTROY
2021-03-29 01:46:51.961229 [DEBUG] switch_core_session.c:1726 Session 4345 (sofia/internal/6@10.10.10.1:5060) Locked, Waiting on external entities
2021-03-29 01:46:51.961229 [NOTICE] switch_core_session.c:1744 Session 4345 (sofia/internal/6@10.10.10.1:5060) Ended
2021-03-29 01:46:51.961229 [NOTICE] switch_core_session.c:1748 Close Channel sofia/internal/6@10.10.10.1:5060 [CS_DESTROY]
2021-03-29 01:46:51.961229 [DEBUG] switch_core_state_machine.c:739 (sofia/internal/6@10.10.10.1:5060) Running State Change CS_DESTROY (Cur 0 Tot 4346)
2021-03-29 01:46:51.961229 [DEBUG] switch_core_state_machine.c:749 (sofia/internal/6@10.10.10.1:5060) State DESTROY
2021-03-29 01:46:51.961229 [DEBUG] mod_sofia.c:364 sofia/internal/6@10.10.10.1:5060 SOFIA DESTROY
2021-03-29 01:46:51.961229 [DEBUG] switch_core_state_machine.c:181 sofia/internal/6@10.10.10.1:5060 Standard DESTROY
2021-03-29 01:46:51.961229 [DEBUG] switch_core_state_machine.c:749 (sofia/internal/6@10.10.10.1:5060) State DESTROY going to sleep
freeswitch@vmPBX1>
