Caller ID help please.
straitllc
All of the DID's on my server are showing the same caller ID on outbound calls. I have tried all that I have found on thee forums and nothing has changed. Thank you ahead of time on where to begin.
Lim00n
38
11
What do you have set as outbound caller id in the extension? Did you copy them and perhaps all have the same setting there? Do you set the outbound caller id in the outbound route perhaps? It should be something like effective_caller_id_number=${outbound_caller_id_number} and not effective_caller_id_number=all_the_same_number. If everything seems OK, maybe the provider is changing the outbound caller id? Check if the invites being sent have different caller_ids.
