Can we have separate provisioning credentials for each domain?
junction1153
52
11
I already tried going to default settings --> provisioning and copied http_auth_username and http_auth_password to the other domain, but it will not load the file unless I explicitly use the credentials from default settings.
Running on Debian 10, last git pull was 2 weeks ago
Thank you
Yes, you can. Infact you can make any default setting different on a per domain basis.
In Advanced->Default Settings, check the box on the left for each setting you wish to copy to a specific domain and then click the Copy button. You will then see a Domain drop down list appear, select the domain and click Paste.
Once you have done this, you will see the copied settings under Advanced-Domains and selecting the domain you are interested in. In the screenshot below, I have copied the setting http_auth_password, you can now edit this here to be different from the default, or from any other domain for that matter.
I hope that helps.
