CID Lookup from Contacts
sbenwellp
15
Has anyone managed to get CID Lookup from Contacts on FusionPBX? I'm just looking to add some contacts into FusionPBX and if they call for it to use the names from contacts to send to the phones I'm sure it's meant to work like this but I can't find the correct way to enable it!
krooney
172
16
you can install dialplan tools and create a cid lookup dialplan
Application = lua
data = cidlookup.lua ${uuid} ${domain_uuid}
Domain = Global
Enables = True
Then you can add in destinations in first position
