custom dialplan for newly created domains
agree
135
24
I would like to create all my new domains with my customize dialplans and features how can this be done?
agree
135
24
Maybe I didn't explain my question well enough. My question is where is located the default dialplan for newly created domains
I would like to customize it
agree
135
24
but if I make it global and I enable or disable it, it will apply to all domains
roger_roger
198
19
You can also create some postgress sql commands that will create what you need; take a look at the fusionpbx database and you'll see what to do.
