P pacolopz New Member May 18, 2023 9 0 1 37 Jun 21, 2023 #1 Hi all, does someone knows why the fusionpbx dashboard shows 100% CPU usage but when I do top on the server it is less than 1%
hfoster Active Member Jan 28, 2019 698 86 28 35 Jun 22, 2023 #2 How odd, Debian 11? Is this a fresh, brand new install?
whut Active Member Dec 23, 2022 311 39 28 Jun 22, 2023 #3 Is this a virtual machine? If so, look at the "st" value in top. This is the CPU steal % from other VPS on the server. Look here https://www.pbxforums.com/threads/cpu-steal.7027/ Also look at htop or top to look for services using way too many resources even though your summary looked good. Reactions: bdmonsey
P pacolopz New Member May 18, 2023 9 0 1 37 Jul 6, 2023 #4 Hi @hfoster it is a fresh install, FreeBSD 13.2
P pacolopz New Member May 18, 2023 9 0 1 37 Jul 6, 2023 #5 @whut yes you are right this is a VM and This is the CPU steal % from other VPS on the server thanks
whut Active Member Dec 23, 2022 311 39 28 Jul 6, 2023 #6 pacolopz said: @whut yes you are right this is a VM and This is the CPU steal % from other VPS on the server thanks Click to expand... That is A LOT of CPU steal. Highly Unacceptable level.
