Dialplan processing for outbound routes
agree
135
24
where in the dialplan does the regex for outbound routes being evaluated and where in the dialplan is it getting routed to the outbound route
in the cli, I see it starts off by processing the regular dialplan and then it moves to the outbound dialplan but I don't see in the dialplan where it happens?
That's all hidden from the user, why do you need to see this, it may help pointing you to the right place? They will all be entries in the dialplan part of the DB but they are not displayed.
agree
135
24
I was just wondering if I"m missing something.
btw, what would be the best way to check a user's outbound regex from a Lua script, through the database or is there any simpler way?
