Different default settings for different Domains
Conker
12
Hey All,
I tried searching the help docs and old forum posts to see if I could figure this out on my own.
We have quite a few domains. We have one client that wants Supervised Transfer, while the other clients want blind transfer. I would like to have different values for the following default for different domains:
yealink_dsskey_transfer_mode
Any way to do this?
TIA.
Update on this. I thought I had it figured out. I went to Advanced -> Domains and selected a test domain
In the domain details, I added a new one line configuration and copied box for box the setting I was trying to modify from the "Default Settings" page.
Saved it and sent out the provision to a test phone. It did not change the setting. Doesn't seem to be working.
Any ideas?
did you check in the provisioning cfg file if you have this line:
transfer.dsskey_deal_type = {$yealink_dsskey_transfer_mode}
Yes, that is in the config correctly. I can globally set it to Blind or Supervised and it will update the phones. I just can't seem to control it at a domain level.
I did, but it gets overwritten by the server every time it refreshed the provisioning.
device level I mean in fusionpbx devices you can manually add provisioning settings that overrides provisioning settings from default and domain level
Reactions: Conker
