Errors after changes, restored fusionpbx DB and now get blank page with <!--{project_path}--> in a lot of the asset URLs
aitp/nadmin
38
Hi PBXForums community,
I'm having some trouble with the errors attached. I encounter the same types of errors after:
  • Restoring the fusionpbx database from a backup
  • changing any files in /var/www/fusionpbx/theme/default
Does anyone have any idea how i should proceed to troubleshoot? Thanks in advance!
Notice: Undefined variable: default_login in /var/www/fusionpbx/resources/footer.php(76) : eval()'d code on line 489
Notice: Undefined index: menu_brand_text in /var/www/fusionpbx/resources/footer.php(76) : eval()'d code on line 493
Notice: Undefined index: menu_brand_type in /var/www/fusionpbx/resources/footer.php(76) : eval()'d code on line 494
Notice: Undefined index: menu_brand_image in /var/www/fusionpbx/resources/footer.php(76) : eval()'d code on line 49
  • Notice: Undefined index: menu_main_icons in /var/www/fusionpbx/resources/footer.php(76) : eval()'d code on line 527
markjcrane
450
162
You need to turn off notices in /etc/fusionpbx/config.php remove the comment // in front of this line. Located at the bottom of the file.
error_reporting (E_ALL ^ E_NOTICE); // Report everything except notice
aitp/nadmin
38
Thanks for the detailed response!
I had un-commented the error reporting line while trying to troubleshoot. I had so much trouble with it, I ended up rebuilding the configs by hand (my clicking finger hurts). Working on a better BCDR plan soon. :)
Thanks again for the time and expertise!
aitp/nadmin
38
Hi Mark and PBXForums community.
This is my initial issue after running the scripts here : https://www.pbxforums.com/threads/fusionpbx-restore-backup-to-new-server.2900/
The database looks like it successfully restores, but this is what I get in the webUI when browsing... Some more screenshots for reference.
I unquoted the show errors line while trying to figure out what was broken, but i lack the understanding to continue troubleshooting.
Thanks in advance for the guidance! I'm super grateful for the help!
Tail from /var/log/ngninx/error.log:
2019/07/06 01:05:36 [error] 20754#20754: *5 open() "/var/www/fusionpbx/<!--{project_path}-->/resources/bootstrap/js/bootstrap.min.js" failed (2: No such file or directory), client: 1.1.1.1, server: fusionpbx, request: "GET /%3C!--%7Bproject_path%7D--%3E/resources/bootstrap/js/bootstrap.min.js HTTP/1.1", host: "1.1.1.1", referrer: "https://1.1.1.1/"
2019/07/06 01:05:36 [error] 20754#20754: *4 open() "/var/www/fusionpbx/<!--{project_path}-->/resources/bootstrap/js/bootstrap-datetimepicker.min.js" failed (2: No such file or directory), client: 1.1.1.1, server: fusionpbx, request: "GET /%3C!--%7Bproject_path%7D--%3E/resources/bootstrap/js/bootstrap-datetimepicker.min.js HTTP/1.1", host: "1.1.1.1", referrer: "https://1.1.1.1/"
2019/07/06 01:05:36 [error] 20754#20754: *2 open() "/var/www/fusionpbx/<!--{project_path}-->/resources/bootstrap/js/bootstrap-colorpicker.js" failed (2: No such file or directory), client: 1.1.1.1, server: fusionpbx, request: "GET /%3C!--%7Bproject_path%7D--%3E/resources/bootstrap/js/bootstrap-colorpicker.js HTTP/1.1", host: "1.1.1.1", referrer: "https://1.1.1.1/"
2019/07/06 01:05:36 [error] 20754#20754: *6 open() "/var/www/fusionpbx/<!--{project_path}-->/resources/bootstrap/js/bootstrap-pwstrength.min.js" failed (2: No such file or directory), client: 1.1.1.1, server: fusionpbx, request: "GET /%3C!--%7Bproject_path%7D--%3E/resources/bootstrap/js/bootstrap-pwstrength.min.js HTTP/1.1", host: "1.1.1.1", referrer: "https://1.1.1.1/"
2019/07/06 01:05:36 [error] 20754#20754: *8 open() "/var/www/fusionpbx/<!--{project_path}-->/resources/jquery/jquery.autosize.input.js" failed (2: No such file or directory), client: 1.1.1.1, server: fusionpbx, request: "GET /%3C!--%7Bproject_path%7D--%3E/resources/jquery/jquery.autosize.input.js HTTP/1.1", host: "1.1.1.1", referrer: "https://1.1.1.1/"
2019/07/06 01:05:36 [error] 20754#20754: *2 open() "/var/www/fusionpbx/<!--{project_path}-->/resources/momentjs/moment.js" failed (2: No such file or directory), client: 1.1.1.1, server: fusionpbx, request: "GET /%3C!--%7Bproject_path%7D--%3E/resources/momentjs/moment.js HTTP/1.1", host: "1.1.1.1", referrer: "https://1.1.1.1/"
2019/07/06 01:05:36 [error] 20754#20754: *2 open() "/var/www/fusionpbx/<!--{project_path}-->/resources/bootstrap/js/bootstrap.min.js" failed (2: No such file or directory), client: 1.1.1.1, server: fusionpbx, request: "GET /%3C!--%7Bproject_path%7D--%3E/resources/bootstrap/js/bootstrap.min.js HTTP/1.1", host: "1.1.1.1", referrer: "https://1.1.1.1/"
2019/07/06 01:05:36 [error] 20754#20754: *2 open() "/var/www/fusionpbx/<!--{project_path}-->/resources/bootstrap/js/bootstrap-datetimepicker.min.js" failed (2: No such file or directory), client: 1.1.1.1, server: fusionpbx, request: "GET /%3C!--%7Bproject_path%7D--%3E/resources/bootstrap/js/bootstrap-datetimepicker.min.js HTTP/1.1", host: "1.1.1.1", referrer: "https://1.1.1.1/"
2019/07/06 01:05:36 [error] 20754#20754: *2 open() "/var/www/fusionpbx/<!--{project_path}-->/resources/bootstrap/js/bootstrap-pwstrength.min.js" failed (2: No such file or directory), client: 1.1.1.1, server: fusionpbx, request: "GET /%3C!--%7Bproject_path%7D--%3E/resources/bootstrap/js/bootstrap-pwstrength.min.js HTTP/1.1", host: "1.1.1.1", referrer: "https://1.1.1.1/"
aitp/nadmin
38
Hi @alexoos,
It was so long ago I can't remember exactly what happened and what was done to resolve it.
I think I may have ended up restoring to another debian 9 host just after a vanilla install and it worked again, so I migrated to that host.
Sorry I wasn't able to help.
Respectfully,
Auto/nadmi
markjcrane
450
162
Try logout.php and login again. The old code that isn’t working could be cached in the session. Second make sure you Upgrades to latest 4.5.x.
alexoos
17
Thanks for response. I tried running logout.php and it didnt seem to do anything. Also ensured I am using the latest version.
Any other ideas to try?
