Hello everybody and thank you for your time.
Since installing FusionPBX 4.4 from 4.2.3, for some reason, it seems to be behaving differently in so many ways, I'm able to divert incoming calls including those coming from a withheld number, but not able to dial out from the extension, currently using ^(\d{10,11})$ revert back from ^0(.*)$ (DigitalDaz's setup) that is working ok on the 4.2.3 box.
Also, I've ditched the previous solution for withheld incoming calls, due to Simwoods force CLI setting, doesn't seem to support multi-tenant, so I've gone down the farward_all_calls.lua route, 1 CLI per IP, that's why I've installed version 4.4 to accommodate the lua script.
Recap
Call forwarding are working including those received by anonymous callers.
Solution needed, update to this regex ^(\d{10,11})$ to allow 4 digit extensions to pass PSTN calls through the gateway.
Here are the logs from coming from the extension.
2018-09-30 02:57:30.750679 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/2012@pbx4.numbercard.co.uk [c1948677-718c-4007-b25a-ff29b8be8261]
2018-09-30 02:57:30.750679 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/2012@pbx4.numbercard.co.uk) Running State Change CS_NEW (Cur 1 Tot 327)
2018-09-30 02:57:30.750679 [DEBUG] sofia.c:9873 sofia/internal/2012@pbx4.numbercard.co.uk receiving invite from 80.42.33.60:5060 version: 1.6.20 -37-987c9b9 64bit
2018-09-30 02:57:30.750679 [DEBUG] sofia.c:10044 IP 80.42.33.60 Rejected by acl "domains". Falling back to Digest auth.
2018-09-30 02:57:30.750679 [DEBUG] sofia.c:2334 detaching session c1948677-718c-4007-b25a-ff29b8be8261
2018-09-30 02:57:30.750679 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [02085555555@pbx4.numbercard.co.uk] from ip 80.42.33.60
2018-09-30 02:57:30.750679 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/2012@pbx4.numbercard.co.uk) State NEW
2018-09-30 02:57:30.910677 [DEBUG] sofia.c:2442 Re-attaching to session c1948677-718c-4007-b25a-ff29b8be8261
2018-09-30 02:57:30.910677 [DEBUG] sofia.c:9873 sofia/internal/2012@pbx4.numbercard.co.uk receiving invite from 80.42.33.60:5060 version: 1.6.20 -37-987c9b9 64bit
2018-09-30 02:57:30.910677 [DEBUG] sofia.c:10044 IP 80.42.33.60 Rejected by acl "domains". Falling back to Digest auth.
2018-09-30 02:57:30.930657 [DEBUG] sofia.c:7084 Channel sofia/internal/2012@pbx4.numbercard.co.uk entering state [received][100]
2018-09-30 02:57:30.930657 [DEBUG] sofia.c:7094 Remote SDP:
v=0
o=- 20122 20122 IN IP4 80.42.33.60
s=SDP data
c=IN IP4 80.42.33.60
t=0 0
m=audio 7078 RTP/AVP 9 0 8 18 101
a=rtpmap:9 G722/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
2018-09-30 02:57:30.930657 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G722:9:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2018-09-30 02:57:30.930657 [DEBUG] switch_core_media.c:4504 Audio Codec Compare [G722:9:8000:20:64000:1] ++++ is saved as a match
2018-09-30 02:57:30.930657 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G722:9:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2018-09-30 02:57:30.930657 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G722:9:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2018-09-30 02:57:30.930657 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2018-09-30 02:57:30.930657 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2018-09-30 02:57:30.930657 [DEBUG] switch_core_media.c:4504 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
2018-09-30 02:57:30.930657 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2018-09-30 02:57:30.930657 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2018-09-30 02:57:30.930657 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2018-09-30 02:57:30.930657 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2018-09-30 02:57:30.930657 [DEBUG] switch_core_media.c:4504 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
2018-09-30 02:57:30.930657 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[G722:9:8000:20:64000:1]
2018-09-30 02:57:30.930657 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMU:0:8000:20:64000:1]
2018-09-30 02:57:30.930657 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMA:8:8000:20:64000:1]
2018-09-30 02:57:30.930657 [DEBUG] switch_core_media.c:4365 Set telephone-event payload to 101@8000
2018-09-30 02:57:30.930657 [DEBUG] switch_core_media.c:3061 Set Codec sofia/internal/2012@pbx4.numbercard.co.uk G722/8000 20 ms 160 samples 64000 bits 1 channels
2018-09-30 02:57:30.930657 [DEBUG] switch_core_codec.c:111 sofia/internal/2012@pbx4.numbercard.co.uk Original read codec set to G722:9
2018-09-30 02:57:30.930657 [DEBUG] switch_core_media.c:4708 Set telephone-event payload to 101@8000
2018-09-30 02:57:30.930657 [DEBUG] switch_core_media.c:4767 sofia/internal/2012@pbx4.numbercard.co.uk Set 2833 dtmf send payload to 101 recv payload to 101
2018-09-30 02:57:30.930657 [DEBUG] sofia.c:7507 (sofia/internal/2012@pbx4.numbercard.co.uk) State Change CS_NEW -> CS_INIT
2018-09-30 02:57:30.930657 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/2012@pbx4.numbercard.co.uk) Running State Change CS_INIT (Cur 1 Tot 327)
2018-09-30 02:57:30.930657 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/2012@pbx4.numbercard.co.uk) State INIT
2018-09-30 02:57:30.930657 [DEBUG] mod_sofia.c:90 sofia/internal/2012@pbx4.numbercard.co.uk SOFIA INIT
2018-09-30 02:57:30.930657 [DEBUG] switch_core_state_machine.c:40 sofia/internal/2012@pbx4.numbercard.co.uk Standard INIT
2018-09-30 02:57:30.930657 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/2012@pbx4.numbercard.co.uk) State Change CS_INIT -> CS_ROUTING
2018-09-30 02:57:30.930657 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/2012@pbx4.numbercard.co.uk) State INIT going to sleep
2018-09-30 02:57:30.930657 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/2012@pbx4.numbercard.co.uk) Running State Change CS_ROUTING (Cur 1 Tot 327)
2018-09-30 02:57:30.930657 [DEBUG] switch_channel.c:2249 (sofia/internal/2012@pbx4.numbercard.co.uk) Callstate Change DOWN -> RINGING
2018-09-30 02:57:30.930657 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/2012@pbx4.numbercard.co.uk) State ROUTING
2018-09-30 02:57:30.930657 [DEBUG] mod_sofia.c:143 sofia/internal/2012@pbx4.numbercard.co.uk SOFIA ROUTING
2018-09-30 02:57:30.930657 [DEBUG] switch_core_state_machine.c:236 sofia/internal/2012@pbx4.numbercard.co.uk Standard ROUTING
2018-09-30 02:57:30.930657 [INFO] mod_dialplan_xml.c:637 Processing 02081802497 <2012>->02085555555 in context pbx4.numbercard.co.uk
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->user_exists] continue=true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (PASS) [user_exists] () =~ // break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
2018-09-30 02:57:30.970661 [DEBUG] freeswitch_lua.cpp:365 DBH handle 0x7fa8341b9a30 Connected.
2018-09-30 02:57:30.970661 [DEBUG] freeswitch_lua.cpp:382 DBH handle 0x7fa8341b9a30 released.
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk set(user_exists=false)
2018-09-30 02:57:30.970661 [DEBUG] mod_dptools.c:1548 SET sofia/internal/2012@pbx4.numbercard.co.uk [user_exists]=[false]
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->caller-details] continue=true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Action set(caller_destination=${destination_number}) INLINE
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk set(caller_destination=02085555555)
2018-09-30 02:57:30.970661 [DEBUG] mod_dptools.c:1548 SET sofia/internal/2012@pbx4.numbercard.co.uk [caller_destination]=[02085555555]
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Action set(caller_id_name=${caller_id_name}) INLINE
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk set(caller_id_name=2012)
2018-09-30 02:57:30.970661 [DEBUG] mod_dptools.c:1548 SET sofia/internal/2012@pbx4.numbercard.co.uk [caller_id_name]=[2012]
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Action set(caller_id_number=${caller_id_number}) INLINE
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk set(caller_id_number=2012)
2018-09-30 02:57:30.970661 [DEBUG] mod_dptools.c:1548 SET sofia/internal/2012@pbx4.numbercard.co.uk [caller_id_number]=[2012]
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->call-direction] continue=true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk ANTI-Action export(call_direction=local)
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->variables] continue=true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (PASS) [variables] () =~ // break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Action export(origination_callee_id_name=${destination_number})
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->user_record] continue=true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (PASS) [user_record] () =~ // break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Action set(user_record=${user_data ${destination_number}@${domain_name} var user_record}) INLINE
2018-09-30 02:57:30.990666 [DEBUG] freeswitch_lua.cpp:365 DBH handle 0x7fa8341b9a30 Connected.
2018-09-30 02:57:30.990666 [DEBUG] freeswitch_lua.cpp:382 DBH handle 0x7fa8341b9a30 released.
2018-09-30 02:57:31.010667 [DEBUG] freeswitch_lua.cpp:382 DBH handle 0x7fa8341b9a30 released.
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk set(user_record=)
2018-09-30 02:57:31.010667 [DEBUG] mod_dptools.c:1548 SET sofia/internal/2012@pbx4.numbercard.co.uk [user_record]=[UNDEF]
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk set(from_user_exists=true)
2018-09-30 02:57:31.010667 [DEBUG] mod_dptools.c:1548 SET sofia/internal/2012@pbx4.numbercard.co.uk [from_user_exists]=[true]
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [user_record] ${call_direction}() =~ /^inbound$/ break=never
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [user_record] ${call_direction}() =~ /^outbound$/ break=never
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [user_record] ${call_direction}() =~ /^local$/ break=never
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Action set(from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}) INLINE
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk set(from_user_record=)
2018-09-30 02:57:31.010667 [DEBUG] mod_dptools.c:1548 SET sofia/internal/2012@pbx4.numbercard.co.uk [from_user_record]=[UNDEF]
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->redial] continue=true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [redial] destination_number(02085555555) =~ /^(redial|\*870)$/ break=on-true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (PASS) [redial] () =~ // break=never
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->speed_dial] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [speed_dial] destination_number(02085555555) =~ /^\*0(.*)$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->default_caller_id] continue=true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk set(emergency_caller_id_name=)
2018-09-30 02:57:31.010667 [DEBUG] mod_dptools.c:1548 SET sofia/internal/2012@pbx4.numbercard.co.uk [emergency_caller_id_name]=[UNDEF]
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk set(emergency_caller_id_number=)
2018-09-30 02:57:31.010667 [DEBUG] mod_dptools.c:1548 SET sofia/internal/2012@pbx4.numbercard.co.uk [emergency_caller_id_number]=[UNDEF]
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [default_caller_id] ${outbound_caller_id_number}(2012) =~ /^$/ break=never
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->20122] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [20122] destination_number(02085555555) =~ /^20122$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->20121] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [20121] destination_number(02085555555) =~ /^20121$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->Simwood-T.0] continue=true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (PASS) [Simwood-T.0] destination_number(02085555555) =~ /^(\d{10,11})$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Action set(sip_h_X-accountcode=${accountcode})
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Action export(call_direction=outbound)
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Action unset(call_timeout)
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Action set(hangup_after_bridge=true)
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Action set(effective_caller_id_name=${outbound_caller_id_name})
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Action set(effective_caller_id_number=${outbound_caller_id_number})
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Action set(inherit_codec=true)
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Action set(ignore_display_updates=true)
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Action set(callee_id_number=02085555555)
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Action set(continue_on_fail=true)
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Action set(outbound_prefix=0) INLINE
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk set(outbound_prefix=0)
2018-09-30 02:57:31.010667 [DEBUG] mod_dptools.c:1548 SET sofia/internal/2012@pbx4.numbercard.co.uk [outbound_prefix]=[0]
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Action bridge(sofia/gateway/8fb9e881-7cab-4c78-b702-13f807c29a2a/02085555555)
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->agent_status] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [agent_status] destination_number(02085555555) =~ /^\*22$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->agent_status_id] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [agent_status_id] destination_number(02085555555) =~ /^\*23$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->group-intercept] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [group-intercept] destination_number(02085555555) =~ /^\*8$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->page-extension] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [page-extension] destination_number(02085555555) =~ /^\*8(\d{2,7})$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->eavesdrop] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [eavesdrop] destination_number(02085555555) =~ /^\*33(\d{2,7})$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->call_privacy] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [call_privacy] destination_number(02085555555) =~ /^\*67(\d+)$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->call_return] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [call_return] destination_number(02085555555) =~ /^\*69$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->intercept-ext-polycom] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [intercept-ext-polycom] destination_number(02085555555) =~ /^\*97(\d+)$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->extension_queue] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [extension_queue] destination_number(02085555555) =~ /^\*800(.*)$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->intercept-ext] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [intercept-ext] destination_number(02085555555) =~ /^\*\*(\d+)$/ break=on-true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [intercept-ext] destination_number(02085555555) =~ /^\*\*$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->dx] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [dx] destination_number(02085555555) =~ /^dx$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->openingHours] continue=true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [openingHours] destination_number(02085555555) =~ /^201211$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->att_xfer] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [att_xfer] destination_number(02085555555) =~ /^att_xfer$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->extension-to-voicemail] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [extension-to-voicemail] ${user_exists}(false) =~ /^true$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->send_to_voicemail] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [send_to_voicemail] destination_number(02085555555) =~ /^\*99(\d{2,10})$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->xfer_vm] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [xfer_vm] destination_number(02085555555) =~ /^xfer_vm$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->vmain] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [vmain] destination_number(02085555555) =~ /^vmain$|^\*4000$|^\*98$/ break=never
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [vmain] destination_number(02085555555) =~ /^(vmain$|^\*4000$|^\*98)(\d{2,12})$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->is_transfer] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [is_transfer] destination_number(02085555555) =~ /^is_transfer$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->vmain_user] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [vmain_user] destination_number(02085555555) =~ /^\*97$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->delay_echo] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [delay_echo] destination_number(02085555555) =~ /^\*9195$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->cf] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [cf] destination_number(02085555555) =~ /^cf$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->echo] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [echo] destination_number(02085555555) =~ /^\*9196$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->milliwatt] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [milliwatt] destination_number(02085555555) =~ /^\*9197$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->is_zrtp_secure] continue=true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [is_zrtp_secure] ${zrtp_secure_media_confirmed}() =~ /^true$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk ANTI-Action eval(not_secure)
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->tone_stream] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [tone_stream] destination_number(02085555555) =~ /^\*9198$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->is_secure] continue=true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [is_secure] ${sip_via_protocol}(udp) =~ /tls/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->hold_music] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [hold_music] destination_number(02085555555) =~ /^\*9664$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->recordings] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [recordings] destination_number(02085555555) =~ /^\*(732)$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->directory] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [directory] destination_number(02085555555) =~ /^\*411$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->wake-up] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [wake-up] destination_number(02085555555) =~ /^\*(925)$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->valet_park] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [valet_park] destination_number(02085555555) =~ /^(park\+)?(\*59[0-9][0-9])$/ break=never
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [valet_park] ${sip_h_Referred-By}() =~ /sip.*)@.*/ break=never
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [valet_park] destination_number(02085555555) =~ /^(park\+)?(\*59[0-9][0-9])$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->operator] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [operator] destination_number(02085555555) =~ /^0$|^operator$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->operator-forward] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [operator-forward] destination_number(02085555555) =~ /^\*000$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->do-not-disturb] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [do-not-disturb] destination_number(02085555555) =~ /^\*77$/ break=on-true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [do-not-disturb] destination_number(02085555555) =~ /^\*78$|\*363$/ break=on-true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [do-not-disturb] destination_number(02085555555) =~ /^\*79$/ break=on-true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [do-not-disturb] destination_number(02085555555) =~ /^dnd\+2012$/ break=on-true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->call-forward] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [call-forward] destination_number(02085555555) =~ /^\*72$/ break=on-true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [call-forward] destination_number(02085555555) =~ /^\*73$/ break=on-true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [call-forward] destination_number(02085555555) =~ /^\*74$/ break=on-true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [call-forward] destination_number(02085555555) =~ /^forward\+(\Q2012\E)(?:\/(\d+))?$/ break=on-true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->call_forward_all] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [call_forward_all] ${user_exists}(false) =~ /true/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->follow-me] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [follow-me] destination_number(02085555555) =~ /^\*21$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->clear_sip_auto_answer] continue=true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [clear_sip_auto_answer] ${click_to_call}() =~ /true/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->talking clock date and time] continue=true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [talking clock date and time] destination_number(02085555555) =~ /^\*9172$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->talking clock time] continue=true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [talking clock time] destination_number(02085555555) =~ /^\*9170$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->talking clock date] continue=true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [talking clock date] destination_number(02085555555) =~ /^\*9171$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->call_screen] continue=true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [call_screen] ${call_screen_enabled}(false) =~ /^true$/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->local_extension] continue=true
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [local_extension] ${user_exists}(false) =~ /true/ break=on-false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk parsing [pbx4.numbercard.co.uk->voicemail] continue=false
Dialplan: sofia/internal/2012@pbx4.numbercard.co.uk Regex (FAIL) [voicemail] ${user_exists}(false) =~ /true/ break=on-false
2018-09-30 02:57:31.010667 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/2012@pbx4.numbercard.co.uk) State Change CS_ROUTING -> CS_EXECUTE
2018-09-30 02:57:31.010667 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/2012@pbx4.numbercard.co.uk) State ROUTING going to sleep
2018-09-30 02:57:31.010667 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/2012@pbx4.numbercard.co.uk) Running State Change CS_EXECUTE (Cur 1 Tot 327)
2018-09-30 02:57:31.010667 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/2012@pbx4.numbercard.co.uk) State EXECUTE
2018-09-30 02:57:31.010667 [DEBUG] mod_sofia.c:198 sofia/internal/2012@pbx4.numbercard.co.uk SOFIA EXECUTE
2018-09-30 02:57:31.010667 [DEBUG] switch_core_state_machine.c:328 sofia/internal/2012@pbx4.numbercard.co.uk Standard EXECUTE
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk export(call_direction=local)
2018-09-30 02:57:31.010667 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[local]
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk export(origination_callee_id_name=02085555555)
2018-09-30 02:57:31.010667 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[02085555555]
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk set(RFC2822_DATE=Sun, 30 Sep 2018 02:57:31 +0000)
2018-09-30 02:57:31.010667 [DEBUG] mod_dptools.c:1548 SET sofia/internal/2012@pbx4.numbercard.co.uk [RFC2822_DATE]=[Sun, 30 Sep 2018 02:57:31 +0000]
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk hash(insert/pbx4.numbercard.co.uk-last_dial/2012/02085555555)
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk set(sip_h_X-accountcode=)
2018-09-30 02:57:31.010667 [DEBUG] mod_dptools.c:1548 SET sofia/internal/2012@pbx4.numbercard.co.uk [sip_h_X-accountcode]=[UNDEF]
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk export(call_direction=outbound)
2018-09-30 02:57:31.010667 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[outbound]
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk unset(call_timeout)
2018-09-30 02:57:31.010667 [DEBUG] mod_dptools.c:1693 UNSET [call_timeout]
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk set(hangup_after_bridge=true)
2018-09-30 02:57:31.010667 [DEBUG] mod_dptools.c:1548 SET sofia/internal/2012@pbx4.numbercard.co.uk [hangup_after_bridge]=[true]
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk set(effective_caller_id_name=2012)
2018-09-30 02:57:31.010667 [DEBUG] mod_dptools.c:1548 SET sofia/internal/2012@pbx4.numbercard.co.uk [effective_caller_id_name]=[2012]
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk set(effective_caller_id_number=2012)
2018-09-30 02:57:31.010667 [DEBUG] mod_dptools.c:1548 SET sofia/internal/2012@pbx4.numbercard.co.uk [effective_caller_id_number]=[2012]
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk set(inherit_codec=true)
2018-09-30 02:57:31.010667 [DEBUG] mod_dptools.c:1548 SET sofia/internal/2012@pbx4.numbercard.co.uk [inherit_codec]=[true]
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk set(ignore_display_updates=true)
2018-09-30 02:57:31.010667 [DEBUG] mod_dptools.c:1548 SET sofia/internal/2012@pbx4.numbercard.co.uk [ignore_display_updates]=[true]
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk set(callee_id_number=02085555555)
2018-09-30 02:57:31.010667 [DEBUG] mod_dptools.c:1548 SET sofia/internal/2012@pbx4.numbercard.co.uk [callee_id_number]=[02085555555]
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk set(continue_on_fail=true)
2018-09-30 02:57:31.010667 [DEBUG] mod_dptools.c:1548 SET sofia/internal/2012@pbx4.numbercard.co.uk [continue_on_fail]=[true]
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk bridge(sofia/gateway/8fb9e881-7cab-4c78-b702-13f807c29a2a/02085555555)
2018-09-30 02:57:31.010667 [DEBUG] switch_channel.c:1250 sofia/internal/2012@pbx4.numbercard.co.uk EXPORTING[export_vars] [domain_name]=[pbx4.numbercard.co.uk] to event
2018-09-30 02:57:31.010667 [DEBUG] switch_channel.c:1250 sofia/internal/2012@pbx4.numbercard.co.uk EXPORTING[export_vars] [call_direction]=[outbound] to event
2018-09-30 02:57:31.010667 [DEBUG] switch_channel.c:1250 sofia/internal/2012@pbx4.numbercard.co.uk EXPORTING[export_vars] [origination_callee_id_name]=[02085555555] to event
2018-09-30 02:57:31.010667 [DEBUG] switch_ivr_originate.c:2142 Parsing global variables
2018-09-30 02:57:31.010667 [NOTICE] switch_channel.c:1104 New Channel sofia/external/02085555555 [26ef7a47-d006-4d7e-8d91-1f24b157d883]
2018-09-30 02:57:31.010667 [DEBUG] mod_sofia.c:4819 (sofia/external/02085555555) State Change CS_NEW -> CS_INIT
2018-09-30 02:57:31.030662 [DEBUG] switch_core_state_machine.c:584 (sofia/external/02085555555) Running State Change CS_INIT (Cur 2 Tot 328)
2018-09-30 02:57:31.030662 [DEBUG] switch_core_state_machine.c:627 (sofia/external/02085555555) State INIT
2018-09-30 02:57:31.030662 [DEBUG] mod_sofia.c:90 sofia/external/02085555555 SOFIA INIT
2018-09-30 02:57:31.030662 [DEBUG] sofia_glue.c:1295 sofia/external/02085555555 sending invite version: 1.6.20 -37-987c9b9 64bit
Local SDP:
v=0
o=FreeSWITCH 1538256847 1538256848 IN IP4 167.99.87.27
s=FreeSWITCH
c=IN IP4 167.99.87.27
t=0 0
m=audio 19404 RTP/AVP 9 0 8 101 13
a=fmtp:101 0-16
a=rtpmap:13 CN/8000
a=ptime:20
a=sendrecv
2018-09-30 02:57:31.030662 [DEBUG] switch_core_state_machine.c:40 sofia/external/02085555555 Standard INIT
2018-09-30 02:57:31.030662 [DEBUG] switch_core_state_machine.c:48 (sofia/external/02085555555) State Change CS_INIT -> CS_ROUTING
2018-09-30 02:57:31.030662 [DEBUG] switch_core_state_machine.c:627 (sofia/external/02085555555) State INIT going to sleep
2018-09-30 02:57:31.030662 [DEBUG] switch_core_state_machine.c:584 (sofia/external/02085555555) Running State Change CS_ROUTING (Cur 2 Tot 328)
2018-09-30 02:57:31.030662 [DEBUG] sofia.c:7084 Channel sofia/external/02085555555 entering state [calling][0]
2018-09-30 02:57:31.030662 [DEBUG] switch_core_state_machine.c:643 (sofia/external/02085555555) State ROUTING
2018-09-30 02:57:31.030662 [DEBUG] mod_sofia.c:143 sofia/external/02085555555 SOFIA ROUTING
2018-09-30 02:57:31.030662 [DEBUG] switch_ivr_originate.c:67 (sofia/external/02085555555) State Change CS_ROUTING -> CS_CONSUME_MEDIA
2018-09-30 02:57:31.030662 [DEBUG] switch_core_state_machine.c:643 (sofia/external/02085555555) State ROUTING going to sleep
2018-09-30 02:57:31.030662 [DEBUG] switch_core_state_machine.c:584 (sofia/external/02085555555) Running State Change CS_CONSUME_MEDIA (Cur 2 Tot 328)
2018-09-30 02:57:31.030662 [DEBUG] switch_core_state_machine.c:662 (sofia/external/02085555555) State CONSUME_MEDIA
2018-09-30 02:57:31.030662 [DEBUG] switch_core_state_machine.c:662 (sofia/external/02085555555) State CONSUME_MEDIA going to sleep
2018-09-30 02:57:31.150664 [DEBUG] sofia.c:6257 Remote Reason: 88
2018-09-30 02:57:31.150664 [DEBUG] sofia.c:7084 Channel sofia/external/02085555555 entering state [terminated][488]
2018-09-30 02:57:31.150664 [NOTICE] sofia.c:8273 Hangup sofia/external/02085555555 [CS_CONSUME_MEDIA] [INCOMPATIBLE_DESTINATION]
2018-09-30 02:57:31.150664 [DEBUG] switch_core_state_machine.c:584 (sofia/external/02085555555) Running State Change CS_HANGUP (Cur 2 Tot 328)
2018-09-30 02:57:31.150664 [DEBUG] switch_core_state_machine.c:850 (sofia/external/02085555555) Callstate Change DOWN -> HANGUP
2018-09-30 02:57:31.150664 [DEBUG] switch_core_state_machine.c:852 (sofia/external/02085555555) State HANGUP
2018-09-30 02:57:31.150664 [DEBUG] mod_sofia.c:438 Channel sofia/external/02085555555 hanging up, cause: INCOMPATIBLE_DESTINATION
2018-09-30 02:57:31.150664 [DEBUG] switch_core_state_machine.c:60 sofia/external/02085555555 Standard HANGUP, cause: INCOMPATIBLE_DESTINATION
2018-09-30 02:57:31.150664 [DEBUG] switch_core_state_machine.c:852 (sofia/external/02085555555) State HANGUP going to sleep
2018-09-30 02:57:31.150664 [DEBUG] switch_core_state_machine.c:619 (sofia/external/02085555555) State Change CS_HANGUP -> CS_REPORTING
2018-09-30 02:57:31.150664 [DEBUG] switch_core_state_machine.c:584 (sofia/external/02085555555) Running State Change CS_REPORTING (Cur 2 Tot 328)
2018-09-30 02:57:31.150664 [DEBUG] switch_core_state_machine.c:938 (sofia/external/02085555555) State REPORTING
2018-09-30 02:57:31.150664 [DEBUG] switch_core_state_machine.c:174 sofia/external/02085555555 Standard REPORTING, cause: INCOMPATIBLE_DESTINATION
2018-09-30 02:57:31.150664 [DEBUG] switch_core_state_machine.c:938 (sofia/external/02085555555) State REPORTING going to sleep
2018-09-30 02:57:31.150664 [DEBUG] switch_core_state_machine.c:610 (sofia/external/02085555555) State Change CS_REPORTING -> CS_DESTROY
2018-09-30 02:57:31.150664 [DEBUG] switch_core_session.c:1665 Session 328 (sofia/external/02085555555) Locked, Waiting on external entities
2018-09-30 02:57:31.170677 [DEBUG] switch_ivr_originate.c:3848 Originate Resulted in Error Cause: 88 [INCOMPATIBLE_DESTINATION]
2018-09-30 02:57:31.170677 [INFO] mod_dptools.c:3436 Originate Failed. Cause: INCOMPATIBLE_DESTINATION
EXECUTE sofia/internal/2012@pbx4.numbercard.co.uk eval(not_secure)
2018-09-30 02:57:31.170677 [NOTICE] switch_core_state_machine.c:385 sofia/internal/2012@pbx4.numbercard.co.uk has executed the last dialplan instruction, hanging up.
2018-09-30 02:57:31.170677 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/2012@pbx4.numbercard.co.uk [CS_EXECUTE] [NORMAL_CLEARING]
2018-09-30 02:57:31.170677 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/2012@pbx4.numbercard.co.uk) State EXECUTE going to sleep
2018-09-30 02:57:31.170677 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/2012@pbx4.numbercard.co.uk) Running State Change CS_HANGUP (Cur 2 Tot 328)
2018-09-30 02:57:31.170677 [DEBUG] switch_core_state_machine.c:850 (sofia/internal/2012@pbx4.numbercard.co.uk) Callstate Change RINGING -> HANGUP
2018-09-30 02:57:31.170677 [DEBUG] switch_core_state_machine.c:852 (sofia/internal/2012@pbx4.numbercard.co.uk) State HANGUP
2018-09-30 02:57:31.170677 [DEBUG] mod_sofia.c:432 sofia/internal/2012@pbx4.numbercard.co.uk Overriding SIP cause 480 with 488 from the other leg
2018-09-30 02:57:31.170677 [DEBUG] mod_sofia.c:438 Channel sofia/internal/2012@pbx4.numbercard.co.uk hanging up, cause: NORMAL_CLEARING
2018-09-30 02:57:31.170677 [DEBUG] mod_sofia.c:577 Responding to INVITE with: 488
2018-09-30 02:57:31.170677 [DEBUG] switch_core_state_machine.c:60 sofia/internal/2012@pbx4.numbercard.co.uk Standard HANGUP, cause: NORMAL_CLEARING
2018-09-30 02:57:31.170677 [DEBUG] switch_core_state_machine.c:852 (sofia/internal/2012@pbx4.numbercard.co.uk) State HANGUP going to sleep
2018-09-30 02:57:31.170677 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/2012@pbx4.numbercard.co.uk) State Change CS_HANGUP -> CS_REPORTING
2018-09-30 02:57:31.170677 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/2012@pbx4.numbercard.co.uk) Running State Change CS_REPORTING (Cur 2 Tot 328)
2018-09-30 02:57:31.170677 [DEBUG] switch_core_state_machine.c:938 (sofia/internal/2012@pbx4.numbercard.co.uk) State REPORTING
2018-09-30 02:57:31.170677 [NOTICE] switch_core_session.c:1683 Session 328 (sofia/external/02085555555) Ended
2018-09-30 02:57:31.170677 [NOTICE] switch_core_session.c:1687 Close Channel sofia/external/02085555555 [CS_DESTROY]
2018-09-30 02:57:31.170677 [DEBUG] switch_core_state_machine.c:741 (sofia/external/02085555555) Running State Change CS_DESTROY (Cur 1 Tot 328)
2018-09-30 02:57:31.170677 [DEBUG] switch_core_state_machine.c:751 (sofia/external/02085555555) State DESTROY
2018-09-30 02:57:31.170677 [DEBUG] mod_sofia.c:343 sofia/external/02085555555 SOFIA DESTROY
2018-09-30 02:57:31.170677 [DEBUG] switch_core_state_machine.c:181 sofia/external/02085555555 Standard DESTROY
2018-09-30 02:57:31.170677 [DEBUG] switch_core_state_machine.c:751 (sofia/external/02085555555) State DESTROY going to sleep
2018-09-30 02:57:31.310662 [DEBUG] switch_core_state_machine.c:174 sofia/internal/2012@pbx4.numbercard.co.uk Standard REPORTING, cause: NORMAL_CLEARING
2018-09-30 02:57:31.310662 [DEBUG] switch_core_state_machine.c:938 (sofia/internal/2012@pbx4.numbercard.co.uk) State REPORTING going to sleep
2018-09-30 02:57:31.310662 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/2012@pbx4.numbercard.co.uk) State Change CS_REPORTING -> CS_DESTROY
2018-09-30 02:57:31.310662 [DEBUG] switch_core_session.c:1665 Session 327 (sofia/internal/2012@pbx4.numbercard.co.uk) Locked, Waiting on external entities
2018-09-30 02:57:31.310662 [NOTICE] switch_core_session.c:1683 Session 327 (sofia/internal/2012@pbx4.numbercard.co.uk) Ended
2018-09-30 02:57:31.310662 [NOTICE] switch_core_session.c:1687 Close Channel sofia/internal/2012@pbx4.numbercard.co.uk [CS_DESTROY]
2018-09-30 02:57:31.310662 [DEBUG] switch_core_state_machine.c:741 (sofia/internal/2012@pbx4.numbercard.co.uk) Running State Change CS_DESTROY (Cur 0 Tot 328)
2018-09-30 02:57:31.310662 [DEBUG] switch_core_state_machine.c:751 (sofia/internal/2012@pbx4.numbercard.co.uk) State DESTROY
2018-09-30 02:57:31.310662 [DEBUG] mod_sofia.c:343 sofia/internal/2012@pbx4.numbercard.co.uk SOFIA DESTROY
2018-09-30 02:57:31.310662 [DEBUG] switch_core_state_machine.c:181 sofia/internal/2012@pbx4.numbercard.co.uk Standard DESTROY
2018-09-30 02:57:31.310662 [DEBUG] switch_core_state_machine.c:751 (sofia/internal/2012@pbx4.numbercard.co.uk) State DESTROY going to sleep
2018-09-30 03:01:12.310702 [WARNING] sofia_reg.c:1792 SIP auth challenge (REGISTER) on sofia profile 'internal' for [2013@pbx4.numbercard.co.uk] from ip 80.42.33.60
Recap
v=0
s=SDP data
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
Local SDP:
v=0
s=FreeSWITCH
t=0 0
a=fmtp:101 0-16
a=rtpmap:13 CN/8000
a=ptime:20
a=sendrecv
