External to Extension Not Working
taylorman57
I have fusionpbx setup with Twilio. It was working flawlessly when I was working on the development. Then I walked away from things for several months and now I am not able to receive incoming calls. The server has been offline so I know there were no updates to any of the software.
I can call out from a ciscoIP phone or the grandstream sip app just fine
I can call from one internal extension to another just fine (on the same network, or from different networks)
I temporarily changed the inbound destination to a voicemail instead of an extension and when I called from the external number I got the voicemail
But when I set the inbound number to one of the extensions I just get silence on the line and the extension never rings.
Any ideas where to start? It doesn't seem to be an IP or firewall issue, nor does it seem to be a registration isue.
megaman
How long are your registration timers set for?Make it 120.
Hi DigitalDaz, I want to set up fusionpbx on azure vm but the extension does not register and also the audio is not working...
What can be the problem please?
I'll be waiting for your response, thanks.
