Feature codes to call block numbers (freepbx)
elkato
30
Wanted to know if could be possible to use (create) feature codes like Freepbx to handle call blocking numbers from telephone:
Specifically this function:
  • Dialing *32 will blacklist the last number that dialed your phone based on the Caller ID of the number that called you.
Any help will be much appreciated.
Thanks in advance!
nktech1135
51
us
In destinations>dial plan there is a disabled call block function. I've not played with it, but it seems to me that with some customization that might do what you want.
elkato
30
Right, but that dialplan is the one to use as described on fusionpbx documentation. The fusionpbx module you need to user from the application menu.
Not something to user dialing feature code, that will need to capture last received call number to be able to block.
But don't know how to do that :(
