First go round with FusionPBX w/ GXP2160 & WP820
btil
13
Just loaded FusionPBX on a PI 4 and like to use the GXP2160 for the 24 button BLF panel. Have tried programming a Call Park and Monitored Call Park button on the physical buttons using *5901. The park togles and works fine either way....however the Park never lights and the Monitored stays green. How is the end user to know if the call is parked?
Cannot get the WP820 to register. Provisioning doesn't seem to work to or from the PBX from either the GXP or the WP.
Any direction would be helpful, Thank you.
When I have don Monitored Call Park on Grandstream phones, I have set it to park+*5901. That has worked for me to get the color to change to red when a call is in park.
Hope that helps,
Shredder
I also use the dialplan { x+ | \+x+ | *x+ | *xx*x+ | \p\a\r\k\+*x+ |\f\l\o\w+*x+}. Are you using gdms.cloud to provision the WP820? I have a few out there and I wasn't impressed. The Dect series does work well though.
