Freeswitch 1.9
yukon
138
14
Hello, anyone running fusionpbx with freeswitch 1.9? Any issues? Anything to be aware of?
Davesworld
90
11
This is quite an old thread that someone responded to. I'm sure 1.8.x has little to to with whether or not 9 will be compatible with the fusionpbx front end, it's just too speculative at this stage of Freeswitch development.
I have no idea what you were wanting to install it on last Septemeber 2018 when you asked. I use Debian myself. I especially do not know where you were getting version 1.9 as of last September if you were in fact able to do so.
@czbg You should actually have a problem. Dial in to one of your extensions from outside, then hang up from the outside. Your call should still be showing on the extension.
czbg
33
Hi DD, what do you mean exactly? I've called from mobile to inside, hangup on mobile before answer or after answer and I do not see nothing in show channels. What do you mean by "showing on the extension" ?
There is a nat bug that should be affecting you. Don't look at the show channels, look on the phone itself, is it hung up? It shouldn't be
czbg
33
I do not have NAT on this system, it's on public IP, connected to the ACME SBC over TLS trunk. Phones are also connected through the SBC. So, you are probably talking about a problem from a sticky thread above? I saw you already found a solution, good job!
