Freeswitch Failing on no Primary Key
mydigitalself
71
Good Afternoon All,
I am in the process of testing a replicated setup, with an end goal of a realtime backup server for failover and for users to log into the web interface of either server to see active calls and registrations on their domain.
My test setup is 2 servers both running:
Debian 10
Freeswitch 10.0.1
FusionPBX 4.5.13
PostgreSQL 9.4
Replicating via BDR FusionPBX works perfectly
Freeswitch can be added to the BDR but starts to fail once a variable of dsn is set with a value of below, in the fusionpbx gui.
"pgsql://hostaddr=127.0.0.1 port=5432 dbname=freeswitch user=fusionpbx password=<password> options=''"
ERROR: Cannot run UPDATE or DELETE on table tasks because it does not have a PRIMARY KEY.
HINT: Add a PRIMARY KEY to the table
From the FusionPBX install scripts it appears to be creating a _uuid column in all freeswitch tables and setting a primary key.
I have Freeswitch setup to use pgsql as it's core database.
Any suggestions and/or a possible different method to be able to see calls/registrations from server1 while logged into server2's GUI?
Thanks,
mydigitalself
71
I did and while it was a relatively simple fix the amount of time it took to figure out, makes me wish I had taken the advanced class. I recreated the freeswitch database.
Neyamt
20
How you did it ?, because when i try to drop the database its complaining about BDR relation. Anyone can help on this ?
