I have been running fusionpbx 4.25 for a while with multiple tenants with no issues.
i have installed the new version of fusionpbx 4.5.11 and setting it up as the previous version i have noticed some menu options are not available.
Like under variables the domain option is not there- default settings the adminer is missing ( i read it was removed ) but is there an other option ?
The setup went fine i have managed to register gateway and extensions with no issues. But when i try to call the number my logs show all attempts and then rejects the call with the error below.
My question is, is there something i missing with the new version ? i have also added the provider in the acl and same issue.
Any help would be appreciated. I am using voip.ms as the carrier and I have setup multiple domains for each client
2020-02-07 09:42:57.788886 [WARNING] sofia_reg.c:2929 Can't find user [010101_test@00.00.00.00] from 192.175.96.69
You must define a domain called '00.00.00.00' in your directory and add a user with the id="010101_test" attribute
2bf3012f-92ac-4ad1-aa69-dba6f827e2b7 2020-02-07 09:42:57.788886 [NOTICE] sofia.c:2432 Hangup sofia/external/2122122222@192.175.96.69 [CS_NEW] [CALL_REJECTED]
