FusionPBX 5.6 Released
markjcrane
798
324
63
51
- Release date: 21 September 2026
New Features
  • Login
    • Remember Me - Added Remember Me (1-week session)
    • Passkey support through WebAuthn.
  • Home
    • New Domain Profile for commonly used domain settings.
    • Global Profile pages for simplified common default settings
  • Themes
    • New theme feature allowing per-user, per-domain, or global theme switching (with default light/dark options).
  • Accounts & Dialplan
    • Drag-and-drop UI improvements for device keys and dialplan details.
  • Applications
    • Added XML CDR file system trigger support (no need to poll the file system), an advanced CDR search with multi-select extensions, a map for recordings/MOH/streams, a Web Socket based Operator Panel, Paging Groups, and drag-and-drop for phrase details.
  • Status
    • Improved stability, security, and reliability of the transcribe queue.
  • Advanced
    • New Services page and dashboard widgets.
  • General
    • Long drop down select lists (domains, destinations, recordings, etc.) are now **searchable** to speed up selection.
      In short: a batch of usability improvements (drag-and-drop, searchable drop downs, themes, Remember Me), new operational tools (operator panel, paging groups, CDR search), and some stability/security fixes.
Additional Information
- Release notes on the website. https://www.fusionpbx.com
- Upgrade Notes. https://docs.fusionpbx.com/en/latest/advanced/version_upgrade.html
- GitHub notes on the release. https://github.com/fusionpbx/fusionpbx/releases/tag/5.6.5
Reactions: gflow
