I have somewhat of a strange issue happening with my FusionPBX. When attempting to register a softphone, the error log shows that Freeswitch is not evaluating the domain portion of the uri. Has anyone ran into this before? For I changed the domain and IP below, but everything else is exactly as the log show it.
It may be of note as well that even if I manually set the authentication user in the softphone, I get an auth failure. I know the password is correct as I'm copying it directly from Fusion.
2019-03-07 22:04:42.074727 [WARNING] sofia_reg.c:2906 Can't find user [102@$${domain}] from X.X.X.X
You must define a domain called '$${domain}' in your directory and add a user with the id="102" attribute and you must configure your device to use the proper domain in it's authentication credentials.
2019-03-07 22:04:42.074727 [WARNING] sofia_reg.c:1737 SIP auth failure (REGISTER) on sofia profile 'internal' for [102@sip.mydomain.com] from ip X.X.X.X.
