FusionPBX on AWS ARM
Edson
59
Dear,
I was wondering if it is possible to install FusionPBX with Freeswitch 1.10.7 on AWS-ARM instance.
I was able to setup it only with Freeswitch 1.10.3 (source install). i guess 1.10.3 is eol, right?
196
1.10.3 is about a year and a half old. Latest release is 1.10.7 you can look here.to see what has changed.
That being said, I've never tried AWS-ARM install, but others have had good luck using Raspberry Pi's. Since Pi's are ARM based, my guess is it would probably work much the same in AWS. Why not just use a standard instance?
Edson
59
@ad5ou Thanks a lot. Got it. I dont know if Rasp Pi ARM based solution will fit ARM-AWS, i will check it.
You won't be able to use the packages on aws I wouldn't think as it is arm64 and the Pi packages are 32 bit. There's a good chance you will need to mod the installer script.
No reason overall though why it shouldn't run on there.
