FusionPBX Voicemail Transcript
shadikur
I am having issue implementing voicemail transcription on my FusionPBX. I have configured all the API and other variables on the default settings properly. Besides, enabled voicemail transcript for the specific extension's message option.
I am getting some error on CLI
Rich (BB code):
2019-04-07 12:34:39.393078 [NOTICE] switch_cpp.cpp:1365 [voicemail] TRANSCRIPTION: (null)
You can find full log here https://pastebin.com/G9mTMs8L
Any help would be highly appreciated. Thanks for your time and cooperation.
Kind Regards
Shadikur
What version are you on and can you post a picture of all your transcription variables?
I am using the latest master branch 4.5.3
Voicemails variables has been given below
Any help is highly appreciated. I have been suffering since last few days to make it work.
Thank you so much.
Kind Regards
Shadikur
Everything looks right there... What about on the voicemail page? Is there anywhere to enable transcription at the extension level?
Hmmm.. I have already enabled the transcript on the Massage Page as well
I look forward to hearing from you/ anyone about this. Thank you.
Shadikur
It has been several months since I tested the transcription service (before that note appeared) so I'm not sure.
My best guess would be yes.
I am using the Watson IBM for speech-to-text and I have the same issue. it is not working for me.
@kshah , I have managed to make that work with Microsoft Azure Speech to Text API. It is now working flawlessly. I have tested on the latest Mater branch as well. Working fine so far.
