I am trying to connect an Obi212 GoogleVoice gateway to FusionPBX. I have successfully done this with FreePBX/Asterisk and 3CX, but am running into an issue with Fusion, even after seeing a few of the aids on this across the internet. I have a feeling it has to do with my lack of knowledge with FusionPBX & FreeSwitch.
I have configured a Gateway with "Global" domain, public context and internal profile, and receive the following:
2020-12-10 17:09:42.725967 [WARNING] sofia_reg.c:1794 SIP auth challenge (REGISTER) on sofia profile 'internal' for [obi212@172.16.3.10] from ip 172.16.3.6
2020-12-10 17:09:42.725967 [WARNING] sofia_reg.c:2930 Can't find user [obi212@172.16.3.10] from 172.16.3.6
You must define a domain called '172.16.3.10' in your directory and add a user with the id="obi212" attribute
2020-12-10 17:09:42.725967 [WARNING] sofia_reg.c:1739 SIP auth failure (REGISTER) on sofia profile 'internal' for [obi212@172.16.3.10] from ip 172.16.3.6
This system is a "hobby" install at my house, so I don't have any true domain services running in this environment, so I am confused where this domain and user shlould be listed. (10.172.16.3.1 is listed in the Domains section and is the IP address of the FusionPBX server)
Thanks for any thoughts and insights!
