Greeting sound while the destination is being called
comdif
France
I try to have a welcome message on Inbound during the call progress
I create a Ring group as destination and set Greeting "my_message.wav"
But first the message is read and then the phone is called,
I would like both actions at the same time how to do it ?
Thank's in advance
Christian
Kenny Riley
243
So you want the greeting to play while the phones in the ring group are ringing rather than have the greeting play first and then ring the ring group members?
You should be able to upload a recording to Apps > Recordings and then in your ring group settings you could change the ring back tone to play your uploaded recording.
comdif
France
This is exactly what I do first
and then I try custom inbound route without more luck.
<extension name="3317642xxxx" continue="false" uuid="88f7e774-716a-4087-809b-9356dc03f6da">
<condition field="destination_number" expression="^(3317642xxxx)$">
<action application="export" data="call_direction=inbound" inline="true"/>
<action application="set" data="domain_uuid=b7732327-e3ba-4e3a-85eb-0378bfd31fba" inline="true"/>
<action application="set" data="domain_name=tc2.mysip.fr" inline="true"/>
<action application="set" data="ignore_early_media=true"/>
<action application="set" data="instant_ringback=true"/>
<action application="set" data="ringback=/var/lib/freeswitch/recordings/tc2.mysip.fr/ACCUEILVIERGE.wav"/>
<action application="set" data="transfer_ringback=/var/lib/freeswitch/recordings/tc2.mysip.fr/ACCUEILVIERGE.wav "/>
<action application="transfer" data="600 XML tc2.mysip.fr"/>
</condition>
</extension>
comdif
France
Finaly I just add a
<action application="answer" data=""/>
and seem to work fine but not sure this is the good method.
