Groundwire Voicemail notification
dcitelecom
153
Is there a special way to get voicemail notifications to work on Groundwire? With FreePBX it works right out of the box. Groundwire shows how many voicemails are stored and updates almost immediately when I add or delete a voicemail. In FusionPBX I get nothing. Is there any special setting to get this to work?
Thanks but not working for me. For some reason, I do not get voicemail notifications on Groundwire.
Got it working (with the help of Acrobits). It's not enough to turn on the lua script for voicemail. The lua script for events must be turned on too.
I don't get why the developers choose to turn off some default settings that should really be working right out of the box. Makes the learning process much harder than it has to be.
