Group Manager permissions will not save
question
17
I cannot set or clear any permission in Group Manager heading XML CDR. It is the same for anything under anything about Voice Mail. Saving resets it to how it was.
I can successfully change permissions for Access Controls and other heading items at the top of the list.
Everything under Permissions heading is enabled. I am logged in as admin with superadmin privileges. I have seen this issue by searching the internet but the fixes I have tried have not worked.
This issue has existed for years already. I found myself having to make the changes from the database manually. FS PBX, an alternative to what you are using today, solves a lot of these bugs including this one.
Do you know if anyone has run FS PBX on Amazon AWS t3.micro instance (1GB 2 CPU)? I am currently running FusionPBX on that.
I think 4 GB of ram is the minimum requirement, otherwise it will work fine on AWS. No, it is not ram intensive while running normally; it’s just the initial build process that demands the ram
I installed FS PBX on a 4 GB t3.medium instance to compare. 4 GB is the minimum memory to install, but after installation it looks like I could save the AMI image and install it on a 2 GB t3.small instance. Here is the memory use comparison while logged into their GUIs.
FS PBX on 4 GB t3.medium
total used free shared buff/cache available
Mem: 3955172 1405828 2483564 59332 343300 2549344
Swap: 1048572 0 1048572
FusionPBX on 1 GB t3.micro
Mem: 962280 526260 179288 40296 437212 436020
Since I am the only tenant on my PBX I can probably keep using the 1 GB AMI instance with FusionPBX. But FS PBX is more polished and documented IMO.
Until you run any of the frequently released updates to FS PBX. Then I suspect you need the 4 GB again.
PHP by default has a limit for the size of an HTML form. There is a simple work around use the category drop down or a search term to reduce the size of the HTML form. As long as it reduces the size small enough to work with the php.ini default then it will work and the value will save.
These are controlled in the php.ini the install script for FusionPBX usually takes care of these.
This will get your version of PHP
php -i | grep php.ini
Here are some sed command line commands that can change the values in you PHP.ini file. If your version of PHP is not 8.2 then you would need to adjust the command to match your version of PHP.
/usr/bin/sed 's#post_max_size = .*#post_max_size = 80M#g' -i /etc/php/8.2/fpm/php.ini
/usr/bin/sed 's#upload_max_filesize = .*#upload_max_filesize = 80M#g' -i /etc/php/8.2/fpm/php.ini
/usr/bin/sed 's#;max_input_vars = .*#max_input_vars = 15000#g' -i /etc/php/8.2/fpm/php.ini
The FusionPBX install increase the value of these settings in the php.ini. However, upgrading PHP could set the php.ini values back to it's defaults.
I'll fix this and build the solution into the code so that this issue is resolved permanently.
SOLVED this issue has been permanently fixed in FusionPBX 5.5 and higher.
- This issue is now fixed in FusionPBX in the latest code in the 5.5 and Master branches.
- The setting for max_input_vars is now large enough by default and set as a runtime value so that it is no longer an issue.
So for those using FusionPBX another WIN among many other recent improvements.
I have version 5.5.11
I updated FusionPBX
cd /var/www/fusionpbx
sudo -u www-data git pull
php core/upgrade/upgrade.phps
I edited /etc/php/8.2/fpm/php.ini and verified post_max_size, upload_max_filesize, max_input_vars were written.
I ran all Advanced > Upgrade options
I systemctl restart freeswitch
But in Group Permissions clicking a checkbox under category XML CDR and saving does not save.
However choosing a category in the Category drop down, then it works to save settings and I am glad for that.
However there is still no delete button in the CDR list of call records.
I just updated to get the latest changes
I removed admin from group user, leaving only superadmin. Gemini theorized I get switched to user after login in and that is why I don't see the delete check-boxes in the CDR menu. I have Delete check-boxes in the CDR menu now. I added admin back to group user and re-logged in. The check-boxes are still there. So probably nothing to do with groups.
The most recent upgrade fixed it. Thanks.
The CDR delete xml_cdr_delete permission is not assigned to any group by default. My reason for making it work that way is that it is not expected that delete would be a common task for what is essentially a Call Log.
Reactions: question
