GS Wave QR Scanner
Dean1212
11
Good day, hope everyone is doing well.
Hopefully someone can point me in the right direction. I am looking for the provision template for the GS Wave QR code scanner. I would like to set my codec prefs and TCP instead of UDP.
I have looked through the forum and am not able to find the answer. I have made changes in /var/www/fusionpbx/resources/templates/provision/grandstream/gswave and just wave but with no luck.
Unless it has been recently updated, I don't believe the GS wave app (/var/www/fusionpbx/app/gswave) uses a provision template, instead it builds (in index.php) an XML document in memory that is sent to the QR code generator.
It may be possible to add some more settings to the XML, but I don't know enough about the GS Wave product.
196
The items the QR code populates is limited by what Grandstream accepts in a QR code currently.
The Fusionpbx developers have been in touch with Grandstream and have requested additional fields. Grandstream promises additional features in a future update, but no timeline was given.
