Hardware Configuration for 500 extensions
wouam31
71
Hello everyone.
It's been a few months that I personally use FusionPBX, it's a great system.
The forum helped me a lot! Thank you all!
I would like your feedback on your installations, because I have a client who asks me for a telephony system for 500 extensions, 10 BLF per extension, I think that we will be between 50 and 100 simultaneous communications
I read that some added Sip Profiles, why? is it mandatory? is it advised?
I'm thinking of taking a dedicated server:
CPU: Intel Xeon E3-1230v6 - 4c/8t - 3.5GHz/3.9GHz
Memory: 16 GB DDR4 ECC
Storage: 2 x 2 TB HDD SATA Soft RAID
Public BP: 250 Mbit/s
Do you think that might be enough, or more memory is needed?
Thank you and have a nice day!
Sep 2, 2017
46
On one of my smaller installs, I'm running double the extensions you are on a hosted system with 2vCPU's, 4GB RAM and a 120GB RAID SSD.
It's been running *flawlessly* for several years. Unless you're running a call center in the mix, you probably won't hit your suspected number of simultaneous calls.
