How do I remove 0 and and add +61?
ndakena
14
Hello Team,
I am new to FusionPBX and have been struggling with something
I want that if I dial any 10 digits number, starting with 0, the system should match the number, remove the leading 0, and add +61 before sending the call out. This is because my Australian provider only accepts calls with numbers starting with +61
Can someone help me to realize this?
Thanks very much
Set your outbound route to match something like
^0(\d{10})$
The above condition as shown will match 11 digit numbers starting with 0 and capture the remaining 10 digits
I'm not sure if you meant 0+10 digits or 0+nine digits. If the latter, change the 10 in the regex to 9.
Then find the bridge statement at bottom of created dial plan and edit it to add a "+61" before the $1
Reactions: ndakena
Hello there.
That worked. Thanks a million.
Reactions: ad5ou
^0(\d{10})$
