How to configure UDP NAT
441
If you mean "How do you make your endpoint NAT aware" You can configure STUN, ICE or TRUN, if you endpoint device supports one of those protocols.
Reactions: vuthy09
441
Try enabling rport on your device if you have it.
Correct me if I'm wrong. rport helps in the correction of bad headers caused by NAT, but freeswitch will still report the endpoint as UDP-NAT. If the end point itself is aware of NAT and does not send any headers containing RFC1918 addresses then freeswitch will report the endpoint as UDP.
Reactions: vuthy09
cagriaksu
29
I'm unsure but I know asking for rport indicates that the device is behind NAT
And with some of our locations which are behind CGNAT even before the net reaches their modem, without rport turned on (yealink units) the phone can not even register to fusionpbx.
