Our Fusion PBX is version 4.5.10.
I would like to know how i can disable TLS port in the server.
I have tried the below method. However, the TLS port is still open.
a. Under Advanced->Variable, for SIP Profile for External and Internal, set internal_ssl_enable and external_ssl_enable to False.
b. Under Status->SIP Status, Flush cache, reload ACL and reload XML
c. restart Freeswitch processes
Can anyone advise what is the correct way to disable the TLS port ?
Regards,
Kwang Mien
Regards,
Kwang Mien
