How to enable TLS in Fusion PBX
kwangmien
57
I am using Fusion PBX version 4.4.6.
I am trying to enable TLS for one of my extensions in Fusion PBX.
However, in the Fusion Web Portal, I could not find any TLS settings in the Accounts -> Extension.
Can anyone advise how to enable TLS for extension ?
Thanks.
Regards,
Kwang Mien
kwangmien
57
Thanks for the info.
I followed the steps and the output from the Status -> SIP Status shows that 5061 and 5081 (both TLS ports) is running.
However, when I do a netstat on the server, 5061 and 5081 are not opened. My IP Phone configured as TLS cannot register to Fusion PBX.
Can I know what other settings has to be done ? Are there any logs i can refer to check what is the issue ?
Thanks.
dev
15
I am also facing same issue, netstat on the server, 5061 and 5081 are not opened. Could you please tell how to resolve it?
purrdeta
I had to restart the freeswitch process with `systemctl restart freeswitch.service` to get it to fully listen. I don't know if I skipped a step or could have done it another way.
dev
15
thanks
Thanks a lot. Yes i also tried the same and it worked.
Bifur
Just fyi for anyone else... I had to restart Freeswitch as well to get it to fully listen. This is in the latest master branch (I believe): 4.5.32
