How to implement emergency call logic in fusionpbx ?
neradp
Is it actually possible to define some workflow for emergency call in fusionpbx ?
I have a trunk with limited number of simultaneous calls ... i need to establish emergency call in case the trunk limit is full, to drop some active calls with lower priority ...
I saw that , there is a emergency_notify script in install/scripts/app/ directory.
No start point in fusionpbx docs for emergency call flow :(
Just get more channels, if you are reaching you channel limits then normal calls will be getting dropped too?
The other alternative is to always reserve x channels for emergency calls.
