How to set different outbound/gateway per extension
PJPMontreal
38
Hi Guys,
Please help with tip on how to set different outbound/gateway per extension.
I have 2 gateways (a & b) and 2 extensions. I would like that each extension use its own gateway. Ext 1 -Gateway (a) and Ext 2 -Gateway (b)
How I do that?
Presently incoming goes well per gateway and ext but the outgoing goes all thru same (a) gateway.
415
Add another condition after creating the gateway that matches on the extension number.
415
Yes, once you have created the outbound route, edit it and add another condition at the top.
PJPMontreal
38
Hi Daz,
Can I remove my first condition or edit it and used as condition for Ext/gateway? This is what I have as first condition:
condition ${user_exists} false 0
and let me know if the following is the good way to edit it to only work with ext 101:
condition ${number_alias} 101 0
415
No, your first condition should be the numbers you are matching to send out of the gateway.
Here is an example of one I have that only allows calls from my extensions beginning with 3:
PJPMontreal
38
Wonderful!! Thank you...
How it would look for an specific group of extensions?? exp. 701, 702 and 703 but not the rest of extensions
PJPMontreal
38
give the toll allow code in???
Sorry, I'm lost!!!
How to do that and how the toll will know the rang of extensions I want to allow in each Outbound/gateway
robvandenbulk
65
In Extension you give a toll allow code b.e. LINE1 per Extension for the group (outbound LINE1) LINE1 701 LINE1 702 LINE1 703 LINE1
In outbound routes you give condition ${toll_allow} LINE1 (so ext 701 702 703 can dial out for this route
Reactions: krakastan
PJPMontreal
38
Interesting!!!! I will try and let you know.... THANKS
