How to SIP URI forwarding
efefidn
22
Hello, I have a number from a provider. It works as a register. I want to forward the incoming call to this number to a different location with sip uri. How can I do it, what is your advice?
Inbound Routes, add the number route then bridge it to a SIP URI:
<action application="bridge" data="sofia/external/sip:***@example.com"/>
I can imagine there's more to it from the recipients side, but you'll have to figure that one out. Not much accepts raw invites without some sort of authentication. You might also have to set the transfer_ringback, otherwise I guess it might be silent on transfer?
Source: FreeSwitch - Dialplan XML Documentation
efefidn
22
thnks for answer @hfoster
do i need to add this in dialplan too? And is there a plugin or code that I need to add differently?
