SOLVED Incoming calls get a Subscriber busy message
102
Newbie alert. Just installed FusionPbx on Ubuntu 20.04 - installation was smooth.
Configured extensions - calls between extensions are working.
When an inbound call arrives, the caller gets a busy message.
The access control has only one entry , Its Default is Deny, then under type I have allow - CIDR YY.0.0.0/8 - domain is left empty.
I saw a similar post here https://www.pbxforums.com/threads/inbound-calls-dropping-instantly.608/
but that solution didn't work out for me - could you all be gentle enough to correct my configuration.
ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:30.135592 [NOTICE] switch_channel.c:1118 New Channel sofia/external/xx78757249@YY.187.7.zz:5060 [ff9a9672-e58e-11eb-8151-0d0547e71ea8]
312 ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:30.135592 [DEBUG] switch_core_state_machine.c:585 (sofia/external/xx78757249@YY.187.7.zz:5060) Running State Change CS_NEW (Cur 1 Tot 55)
313 ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:30.135592 [DEBUG] sofia.c:10279 sofia/external/xx78757249@YY.187.7.zz:5060 receiving invite from YY.187.7.zz:5060 version: 1.10.3 -release 64bit
314 2021-07-15 22:36:30.135592 [DEBUG] sofia.c:10373 verifying acl "domains" for ip/port YY.187.7.zz:0.
315 ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:30.135592 [DEBUG] switch_core_state_machine.c:604 (sofia/external/xx78757249@YY.187.7.zz:5060) State NEW
316 2021-07-15 22:36:30.135592 [DEBUG] sofia.c:2434 detaching session ff9a9672-e58e-11eb-8151-0d0547e71ea8
317 ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:40.175594 [WARNING] switch_core_state_machine.c:688 ff9a9672-e58e-11eb-8151-0d0547e71ea8 sofia/external/xx78757249@YY.187.7.zz:5060 Abandoned
318 ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:40.175594 [NOTICE] switch_core_state_machine.c:691 Hangup sofia/external/xx78757249@YY.187.7.zz:5060 [CS_NEW] [WRONG_CALL_STATE]
319 ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:40.175594 [DEBUG] switch_core_state_machine.c:585 (sofia/external/xx78757249@YY.187.7.zz:5060) Running State Change CS_HANGUP (Cur 1 Tot 55)
320 ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:40.175594 [DEBUG] switch_core_state_machine.c:848 (sofia/external/xx78757249@YY.187.7.zz:5060) Callstate Change DOWN -> HANGUP
321 ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:40.175594 [DEBUG] switch_core_state_machine.c:850 (sofia/external/xx78757249@YY.187.7.zz:5060) State HANGUP
322 ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:40.175594 [DEBUG] mod_sofia.c:453 Channel sofia/external/xx78757249@YY.187.7.zz:5060 hanging up, cause: WRONG_CALL_STATE
323 ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:40.175594 [DEBUG] switch_core_state_machine.c:60 sofia/external/xx78757249@YY.187.7.zz:5060 Standard HANGUP, cause: WRONG_CALL_STATE
324 ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:40.175594 [DEBUG] switch_core_state_machine.c:850 (sofia/external/xx78757249@YY.187.7.zz:5060) State HANGUP going to sleep
325 ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:40.175594 [DEBUG] switch_core_state_machine.c:620 (sofia/external/xx78757249@YY.187.7.zz:5060) State Change CS_HANGUP -> CS_REPORTING
326 ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:40.175594 [DEBUG] switch_core_state_machine.c:585 (sofia/external/xx78757249@YY.187.7.zz:5060) Running State Change CS_REPORTING (Cur 1 Tot 55)
327 ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:40.175594 [DEBUG] switch_core_state_machine.c:936 (sofia/external/xx78757249@YY.187.7.zz:5060) State REPORTING
328 ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:40.175594 [DEBUG] switch_core_state_machine.c:174 sofia/external/xx78757249@YY.187.7.zz:5060 Standard REPORTING, cause: WRONG_CALL_STATE
329 ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:40.175594 [DEBUG] switch_core_state_machine.c:936 (sofia/external/xx78757249@YY.187.7.zz:5060) State REPORTING going to sleep
330 ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:40.175594 [DEBUG] switch_core_state_machine.c:611 (sofia/external/xx78757249@YY.187.7.zz:5060) State Change CS_REPORTING -> CS_DESTROY
331 ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:40.175594 [DEBUG] switch_core_session.c:1726 Session 55 (sofia/external/xx78757249@YY.187.7.zz:5060) Locked, Waiting on external entities
332 ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:40.175594 [NOTICE] switch_core_session.c:1744 Session 55 (sofia/external/xx78757249@YY.187.7.zz:5060) Ended
333 ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:40.175594 [NOTICE] switch_core_session.c:1748 Close Channel sofia/external/xx78757249@YY.187.7.zz:5060 [CS_DESTROY]
334 ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:40.175594 [DEBUG] switch_core_state_machine.c:739 (sofia/external/xx78757249@YY.187.7.zz:5060) Running State Change CS_DESTROY (Cur 0 Tot 55)
335 ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:40.175594 [DEBUG] switch_core_state_machine.c:749 (sofia/external/xx78757249@YY.187.7.zz:5060) State DESTROY
336 ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:40.175594 [DEBUG] mod_sofia.c:364 sofia/external/xx78757249@YY.187.7.zz:5060 SOFIA DESTROY
337 ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:40.175594 [DEBUG] switch_core_state_machine.c:181 sofia/external/xx78757249@YY.187.7.zz:5060 Standard DESTROY
338 ff9a9672-e58e-11eb-8151-0d0547e71ea8 2021-07-15 22:36:40.175594 [DEBUG] switch_core_state_machine.c:749 (sofia/external/xx78757249@YY.187.7.zz:5060) State DESTROY going to sleep
First for any newbie - do sofia global siptrace on
The calls were getting rejected as ACL list was incorrect
Go to Access controls -> domains -> allow x.x.x.x/y - leave domain field blank and save
The next issue for me was that the inbound calls didn't come with a destination number, so I had to route it based on incoming ip
