Installing Dedicated Homer SIP Capture Agent
618
A few people have asked for this so here goes, its very quick, I haven't detailed much and though I thought there were QOS stats, there weren't. That may just be because it was to MOH.
Install some prerequisites:
apt update
apt install build-essential automake autoconf libtool-bin flex bison libexpat1-dev libpcap0.8-dev libjson0-dev libuv0.10-dev
Then:
cd /usr/src
git clone https://github.com/sipcapture/captagent.git captagent
cd captagent
./build.sh
./configure
make && make install
To run the capture agent as a daemon use:
/usr/local/captagent/sbin/captagent -d
Reactions: pacmen and krooney
I followed the above , however I am not getting the TLS traffic
I did edit the protocol_tcp file to the .pem directory and the problem didn’t fix it self
Maybe I need to do some kind of reload?
Has anyone been able to get decrypted tls traffic to Homer via captagent?
Good morning, i follow guide.
when start capture-agent
i have this error:
[ERR] protocol_sip.c:533 bad parsing
[ERR] protocol_sip.c:514 SIP PARSE ERROR [-1]
how can fix?
thank you very much
