Internal Auto Answer
Claudio
I have been trying to get internal to work with no luck. Is there a simpler way to do this ? I need it to work on a multi tenant system but specific per domain. Not all customers want that. I have suggested learning to use *8 for intercom but I migrated from an evil pbx that had the ability to enable dialing extensions and the phones auto answer.
Claudio
Claudio
Tried your method still didnt work. Im using yealink phones. I did read that the alert info and call-info need to be set but im not sure in the formatting. This is what is specified.
• Alert-Info: Auto Answer
• Call-Info: answer-after=0
Thanks,
Claudio
EasyBB
240
33
Australia
That would be an issue with your set up then. I just tested my syntax on my Yealink T28 and it is working
alert_info=http://example.com;info=alert-autoanswer;delay=0
May be post a screenshot of your dial plan block.
