Is It Possible to Delete a Domain?
PBXMePlz
102
Hello!
I've run into a scenario where I have a couple domains now under Advanced -> Domains, and I'm hoping maybe I can just remove one. Is this a simple sql query maybe?
Thanks!
- Sam
Just also be aware that the last time I tried this, it doesn't delete everything. There may still be some manual tidying up to be done but to what extent, I don't know.
akruger
To add to this, the delete domain permission is disabled for the superadmin group by default. You'll need to enable that permission first from the group manager.
How would I enable this "delete domain permission"?
196
It was mentioned above.
Advanced > Group manager
Superadmin >permissions
Scroll or search for: domain_settings_delete
Check block
Save
Logout
Login
Your superadmin account can now delete a domain in Advanced>Domains
akruger
Check block
Save
Logout
Login
I am so blind sometimes ... thank-you for your patience
