I have an IVR Main Menu that works perfectly, however one of its options is to load another IVR menu (calling the extension) and that menu is a set of directories, I can see in the logs that it goes to the proper extension and does load the second IVR I created but for some reason it doesn't actually say the text, it instantly ends with "done speaking text" in the logs and the call drops.
I've re-created the IVR menu a few times. It seems any menu after the first one doesn't work right. I've tried smaller text or other random text. I don't know what I am doing wrong, if I am.
I am using cepstral tts engine but it is registered properly as the main menu works fine.
