Limit Concurrent calls per domain
Bashar
Is there a way to limit concurrent calls per domain? For new customers, I usually create a new domain and would like to limit the number of concurrent calls for the new domain. Thanks!
Bashar
Dear EasyBB,
Thank you for your response.
I did not see on the link how to limit concurrent calls per domain. I am new to FusionPBX and have been using the GUI for setup.
Regards!
EasyBB
240
33
Australia
You are better off not limiting per domain to avoid unintended consequences :) Apply the limit on the outbound route as below:
The limit of 1 call is applied at line 50 in the screenshot above. 'hash' is the backend to use; 'gw_limit' is just a string; 'cc93....33' is the gateway(trunk) id; '1' is the limit for calls.
