Monitoring active sessions on a gateway
tfernandez
Hi All,
I am wondering if anyone has found a way to monitor active calls on a gateway. I have multiple SIP trunks to my upstream carriers and want to know what my usage is like so that I can know when to increase my channels.
Up until now, I have gotten the total channels via fs_cli and divided it by 2 which isn't ideal, obviously. It gave me a rough amount.
Ever since adding more carriers, my numbers are less accurate.
I did read on some Freeswitch mailing lists that I can add limits and then monitor that. It seems a bit hacky.
sofia status gateways
command gets me sort of what I need, except that InBound calls do not move.
Anyone have any suggestions?
whut
170
15
I am not certain if this is going in the direction you are wanting, but try this
fs_cli -x "show calls as xml" | grep "<direction>" | awk -F'[<>]' '{print $3}' | sort | uniq -c
Reactions: tfernandez
tfernandez
thank you @whut .
I ended up giving up on their being a built-in way to do this.
I think I was able to extract the per gateway active sessions by parsing the following:
Bash:
fs_cli -x "show detailed_calls"
I have stats that seems to be accurate populating in my zabbix server.
For anyone reading this in the future, here my repo
