Multi-condition extensions with break=never not working as intended
czbg
33
I've found out that any multi-condition extension, which uses break=never does not work. I was trying to set call recording and had troubles with defined call direction recording. First problem is call direction, which is always empty but I'll write about that in another thread. If direction is ok, recording still does not work as intended, because of break=never, which means that if the last conditon matches, action is set to execute, even though the conditions before were not met.
I've found the bug report which describes similar situation: https://freeswitch.org/jira/browse/FS-4935
FS logical AND works only w/o break=never. I've solved this by rewriting user_record extension in XML, because there is no way to define condition regex="all" in the FPBX.
My working user_record is below:
<extension name="user_record" continue="true" uuid="7fa775b3-f465-46e3-94a4-a03258f9ec3f">
    <condition field="" expression="">
        <action application="set" data="user_record=${user_data ${destination_number}@${domain_name} var user_record}" inline="true"/>
        <action application="set" data="from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}" inline="true"/>
    </condition>
    <condition regex="all" break="never">
        <regex field="${user_exists}" expression="^true$"/>
        <regex field="${user_record}" expression="^all$"/>
        <action application="set" data="record_session=true" inline="true"/>
    </condition>
        <regex field="${call_direction}" expression="^inbound$"/>
        <regex field="${user_record}" expression="^inbound$"/>
    </condition>
        <regex field="${call_direction}" expression="^outbound$"/>
        <regex field="${user_record}" expression="^outbound$"/>
        <action application="set" data="record_session2=true" inline="true"/>
    </condition>
        <regex field="${call_direction}" expression="^local$"/>
        <regex field="${user_record}" expression="^local$"/>
    </condition>
    <condition field="${from_user_exists}" expression="^true$" break="never">
        <action application="set" data="from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}" inline="true"/>
    </condition>
        <regex field="${from_user_exists}" expression="^true$"/>
        <regex field="${from_user_record}" expression="^all$"/>
    </condition>
        <regex field="${from_user_record}" expression="^inbound$"/>
    </condition>
        <regex field="${from_user_record}" expression="^outbound$"/>
    </condition>
        <regex field="${from_user_record}" expression="^local$"/>
    </condition>
    <condition field="${record_session}" expression="^true$">
        <action application="set" data="record_path=${recordings_dir}/${domain_name}/archive/${strftime(%Y)}/${strftime(%b)}/${strftime(%d)}" inline="true"/>
        <action application="set" data="record_name=${uuid}_${caller_id_number}_${destination_number}_${strftime(%Y%m%d%H%M)}.${record_ext}" inline="true"/>
        <action application="set" data="recording_follow_transfer=true" inline="true"/>
        <action application="set" data="record_append=true" inline="true"/>
        <action application="set" data="record_in_progress=true" inline="true"/>
        <action application="set" data="${uuid_record ${uuid} start ${record_path}/${record_name}}" inline="false"/>
    </condition>
</extension>
