Multi-tenant outbound dial context
SeanDevoy
I have almost successfully installed multi-tenant FusionPBX.
I have phones registering to different domains just fine. However, when I dial another extension like 230 (from 220) the log shows it NOT using the context defined in the EXTENSION (220). How do I get numbers dialed on internal domains (aliased to internal) to use the domain name as the context. Currently it says like 220 <220>->230 in context "%{domain}"
Any help would be greatly appreciated.
I agree, I know what it SHOULD be. It is defined in the extension. The log shows the call originating from 230@<the correct domain> but it routes in public. Where does that get set? In the SIP profile? What value should "context" have in the profile variables?
@SeanDevoy You shouldn't have to change any of these things, they are all set to the correct defaults, even when creating routes etc.
Paste a call log, maybe we can work out whats going on.
You haven't changed or added to any ACLs have you? That is another thing that doesn't need touching, except for carriers.
Sorry I have no idea what they have done but absolutely you have an ACL issue:
Approved by acl "domains[]". Access Granted.
