I set multiple-registrations=contact to true for the internal sip profile and tried both a profile restart and a freeswitch restart and am experiencing two issues:
1. When 2 phones are registered to the same extension, after the call_timeout value has reached, instead of going to voicemail, it will ring for another round, and then go to voicemail - forget it, I figured this out, was an issue with my config
2. Both sip registrations must be on the same protocol (TLS/TCP/UDP) in order for the simultaneous ringing to work.
I am using Debian 10, installed about a month ago. Please let me know if any additional information is needed.
